    Replicating fan speed as a servo signal on custom PWM pin
    • Captain_squndefined
      Captain_sq
      I posted this question under Hardware and Wiring and that might have been a little off topic, so I'm trying here in the general part instead.
      Is it possible to set up a custom output on the Duet Wifi that will generate a servo signal (1-2 mS) that follow/is proportional to the value of FAN0?
      f ex
      0% = 1.0mS
      100% = 2.0 mS
      If that's not possible, tweaking the FAN0 PWM output itself to produce a 22mS period pulse train with 1-2 mS duty cycle would yield a valid servo signal between 5...9 % in its entire span. Not much to play around with.
      I could solve this in the Slicer (S3D) if math in the G-code was possible with a REPLACE macro that would produce something like this.
      ; Before
      M106 S127
      ; After
      M280 P1 S(([fan_speed_pwm]/255)*1000 +1000) ; S127 "Imaginary" expression
      Any thoughts ? Did I miss something?
      Regards /Thom
      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
        That will be possible when the RepRapFirmware object model is implemented (which I hope will be in firmware 2.03), because at that time maths in GCode commands will be supported. Or you could modify the firmware to set the servo output automatically.
          Captain_sq
          OK, Great! In the mean time I'll just filter the output from S3D through a AutoIt serial editor filter that will perform the conversion.
          Thanks /Thom
