Chimera / Delta / Effector tilt
  • Hi,
    I was wondering about fitting a Chimera hotend / dual extruder to a 3d printer.However it's a delta type printer (Anycubic Kossel Plus)
    And one of the issues can be effector tilt and the offset of the extruder.
    I was wondering, does the duet firmware have options to compensate for this?
    1. Can you set different offsets for different heads?
    2. Considering effector tilt might be a consideration is there an option to compensate for this? I'm thinking perhaps multiple / different calibration settings on the bed based on the tool in use.
  • Okay I managed to answer one of my own questions
    G10 can be used for different tool offsets
    But I'm still wondering if it's possible to have different G30 / G29 / M665 / M666 settings for different tools, to compensate for any effector tilt
  • @garlicbread said in Chimera / Delta / Effector tilt:
    Enough effector tilt to affect the Z of an offset nozzle will also totally destroy X/Y accuracy.
