    Heater stops when Cooling Fan starts
    • SkyRaccoon
      SkyRaccoon last edited by
      Hello everyone,
      I have a 12V power supply on my duet Wifi/printer
      I have recently added a 12V fan to cool the print (I was previously using a 5V fan)
      So I moved the Fan Jumper and plugged the new fan and started a new print.
      1st layer no problem (fan is off)
      2nd layer, fan is switched ON but the Heater just stops...
      I have tried again and each time the FAN starts , the heater stops to heat.
      Have then unplugged the FAN (just to check) and everything is OK, no problem till the end of the print.
      What could be the problem ?
      Thanks
      SR
        Phaedrux Moderator @SkyRaccoon last edited by
        Are you getting any error messages about heater faults?
        • SkyRaccoon
          Yes, but I think I know what's happening...
          I think the fan is strong and blows on the heater making the thermistor thinking that the heater is faulty while this is only coming from the air blowing.
          Gonna put a silicon around it and test... Don't think now it's an electrical problem.
          • SkyRaccoon
            SkyRaccoon last edited by SkyRaccoon
            Yes... that's it .
            So I see two solutions here.
            1] Put A silicon around the head
            2] Turn the head so the thermistor is not facing the air fan flow.
            Or both 🙂
            dc42 1 Reply Last reply Reply Quote 2
              dc42 administrators @SkyRaccoon last edited by
              @skyraccoon said in Heater stops when Cooling Fan starts:
              Yes... that's it .
              Or both 🙂
              Even better is to adjust the fan duct to blow at the print below the nozzle, not at the heater.
