    Proximity of DC input wires to fan problematic? [Solved]
    • botundefined
      bot
      As seen here, the positive and negative wires for the duet input are literally touching the frame of the motor for the always on fan.
      Will this be problematic in terms of noise and induced currents into the input wires? It’s hard managing the routing of these wires in such a tight space!
      Thanks!
      *not actually a robot
        No, that won't cause a problem. But make sure there is no chance of the wires touching the fan blades.
        • botundefined
          bot
          Thank you! I re-did the routing so it's less likely to come in contact with the blade.
