    I2C pyrometer module as temperature sensor
    Third-party add-ons
    • ov_darknessundefined
      ov_darkness
      I'm playing with the idea of using IR probe as bed temp. sensor.
      https://kamami.com/temperature-sensors/557799-pgy-906-modul-pirometru-termometr-ir-z-elementem-mlx90614p.html
      It talks via I2C.
      Is it possible with Duet?
      Pro level AM audit, support and sales.
      Management of 3D scanning and printing services.
      Focused on Central and Eastern Europe.
      • chrishammundefined
        chrishamm administrators
        I don't think RepRapFirmware supports this sensor yet but it could be added if you are familiar with C++ programming.
        Duet software engineer
          We did an interface for a 4-20mA current loop pyrometer for an OEM user a while ago. It used the same daughter board connector that we use for PT100 and thermocouple daughter boards.
          Be aware that I2C should only be used over very short distances, preferably only on a single PCB or between two PCBs that are very close to each other. So I'd recommend that you either use a microcontroller mounted very close to the pyrometer to convert it to an interface and protocol that travel better, or pick a sensor with a different interface.
            ov_darkness
            Thanks for the answer! 🙂
            Maybe I have wrong approach angle with that:
            What I'm looking for is more precise measurement of bed surface, that will be glass or granite. I don't want to use heater thermistor or thermistor in bed, as I want to measure surface temperature.
            • QuentinLeundefined QuentinLe referenced this topic
