    Request (if possible) for greater consistency in G-codes
    Firmware wishlist
    • fcwilt
      fcwilt last edited by fcwilt
      Consider:
      M118: Send Message to Specific Target
      It takes parameters (not all are listed):
      • P which specifies message type
      • S which specifies message to send
      M291: Display message and optionally wait for response
      • P which specifies the message to display
      • S which specifies the message box mode
      I know it is hard to change things that have been out there for sometime but it would be nice if somehow parameter consistency could be improved.
      Perhaps it could be done via new commands that do the same but with consistent parameters.
      Thanks.
      gnydick 1 Reply Last reply Reply Quote 1
      • gnydick
        gnydick @fcwilt last edited by
        @fcwilt I'm definitely like minded on this, but having been a software developer for 20+ years, it's just not going to happen. Keep links to documentation handy, build tools to abstract the ugly if you have to.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @gnydick last edited by
          @gnydick said in Request (if possible) for greater consistency in G-codes:
          I too was a programmer - 35+ years. Started on 80 column punch cards - Fortran and Algol. Ah... those were the days - NOT!
          dc42 1 Reply Last reply Reply Quote 1
            @fcwilt , we try to be consistent in all new GCodes we allocate. For example, all GCodes involving heater numbers that I have introduced use H for the heater number. Unfortunately, we have to be compatible with other firmwares, so maintaining a logical use of parameters isn't always possible.
            fma fcwilt 2 Replies Last reply Reply Quote 0
              dc42 administrators @fcwilt last edited by
              @fcwilt said in Request (if possible) for greater consistency in G-codes:
              Luxury! (spoken with a Yorkshire accent)
              • fma
                fma @dc42 last edited by
                @dc42 said in Request (if possible) for greater consistency in G-codes:
                Well, the most important is to be compatible with slicers... I mean, you need to implement G-Codes the way they use them.
                On the other hand, G-Codes which are used for configuration, or special stuffs slicers don't directly handle, and where people have to manually define in custom scripts (servo usage, for example, as we discussed a few days ago), I'm not sure it is a good idea to always follow other firmwares; It is sometimes better to define new standards.
                Frédéric
                • fcwilt
                  fcwilt @dc42 last edited by
                  It's just my OCD talking.
