    Question about G31
    • fcwilt
      fcwilt last edited by
      What does the Z parameter of the G31 command do?
      Does it affect the values computed by the G32 command?
      After making the needed preparations I ran G32 and then G29. The resulting height map was good.
      However something changed the H value in M665 and at X=0 the nozzle was 0.4 above the bed.
      What happened?
      Thanks.
        The Z parameter of the G31 command tells the firmware how high above the bed the nozzle is when the Z probe triggers. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @dc42 last edited by
          @dc42 said in Question about G31:
          I was not clear. I understand what it is doing in G31 - what I don't understand is where it is ultimately used.
          For example does it play a role in the values computed by G32?
          Or to put it another way if the Z value is wrong in G31 what will malfunction as a result?
          Thanks.
            dc42 administrators @fcwilt last edited by
            @fcwilt said in Question about G31:
            If you use the incorrect Z value in G31, and you use the Z probe to home Z, or to do delta calibration, bed levelling or mesh bed compensation, then the Z=0 position will not correspond to the nozzle just touching the bed. When you print, the nozzle will be too close to the bed or too far away from it.
            • fcwilt
              Thank you - that is very helpful.
