    Statistically-based Bed Compensation and Calibration
    • TLAS
      TLAS last edited by TLAS
      Had an interesting experience with the Smart Effector the other day. I ran bed calibration and got something like this:
      (Shamelessly stolen from TLeTorneau in another thread)
      [https://forum.duet3d.com/assets/uploads/files/1542436419111-bed_level_001_mesh_11172018.png
      What's interesting is that this shows some real mechanical drift of the sensor over time. I had the same problem on the Smart Effector. I doubt that this is an artifact of the print bed, especially since when I changed directions, the lines appeared in the other direction.
      I think an ideal bed probe system would be to implement the following:
      • Randomly determine the probe point order.
        • This would help eliminate sensor drift from the final results.
        • Alternatively, you could probe in reverse directions (although randomly would be better)
      • Perform 3+ measurements at the same point (at random points in time)
        • This gives you mean standard error reduction
      • Implement a localized flatness smoothing
        • Sharp bumps are more likely to be errors than real changes.
        • False sharp bumps can produce problems / deformations in the final print
      Bottom line is that with the statistical methods mentioned above, I think it's possible to achieve a 3X decrease in calibration sensor error. For mechanically based sensors, this could be a real boon and help achieve the accuracy needed for printing.
      • DocTrucker
        DocTrucker last edited by
        Have you checked out the A and S parameters of set probe type?
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
        On the upside for the current method testing in a specific order does give you a fighting chance of driving out sources of error. Randomising the order could potentially hide these patterns giving the false impression of it just being a noisy measurement?
