    Calibrating the Z probe trigger height
    • UnderDoneSushi
      UnderDoneSushi last edited by
      I am currently trying to set the probe trigger height to start a test print. Using the guide:(https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height)
      I am trying to jog the nozzle down to grip a piece of paper but the Mini differential sensor is preventing it. It's a stupid question but I am not sure what to change to get past this point. Using gcode is new to me coming from a preset Printrboard...
      The sensor is being used as my z probe, I am using a printinz plate, and I am getting the correct numbers for if a surface is near (465) and if the sensor is activated (535).
      Here's my config.g:
      ; generated by RepRapFirmware Configuration Tool on Mon Aug 13 2018 00:33:59 GMT-0400 (Eastern Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M550 PIMJ - Printrbot SM ; Set machine name
      M551 Pimj349 ; Set password
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P4 S0 ; Drive 4 goes forwards
      M92 X80 Y80 Z2020 E96 ; Set steps per mm
      ;M92 E420:420 ; set extruder 0 and 1 steps/mm
      M203 X9000 Y9000 Z360 E1000 ; Set maximum speeds (mm/min)
      M201 X2000 Y2000 Z30 E10000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z900 E800 ; Set motor currents (mA)
      M84 S30 ; Set idle timeout
      M208 X250 Y150 Z150 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M558 P1 H3 F120 T9000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z0.0 ; Set Z probe trigger value, offset and trigger height
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X0 Y26 Z0 ; Set tool 0 axis offsets
      • aidar
        aidar last edited by
        Hi.
        Try this https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Checking_the_trigger_height .
          Are you saying that it won't let you jog the nozzle down low enough? If so then it probably thinks you are at Z=0 already and you have the minimum allowed Z height set to zero. You can allow movement behind the limits by sending M564 S0. When you have finished, send M564 S1 to re-apply the limits.
          UnderDoneSushi 1 Reply Last reply Reply Quote 0
          • UnderDoneSushi
            UnderDoneSushi @dc42 last edited by
            @dc42 said in Calibrating the Z probe trigger height:
            M564 S0
            Yeah, the Mini Differential Sensor I assume is stopping it, I didn't know there was a behind the scenes limiting factor.
            Thank you I will try it once I get home and report back!
