    All my fans have stopped working
    • Mklein23
      Mklein23 last edited by
      So I was connecting some part cooling fans for the first time to my duet wifi. I already had an always on fan connected and running to my e3d chimera hot end.
      I was wiring the part cooling fans and got one of them (one of 2) to run. But I couldn't get the other one to run. I thought it was maybe a dead fan so I tried to connect it to the running one and now neither of them run. And in the midst of trying to see if I had a dead fan or a bad connection, I managed to make ALL the fans to stop running. I saw another thread of someone with the same issue, and it was fixed by soldering a new wire on the back of the board. but they were using 12v fans. I'm using 5 volt fans.
      What should I do?
        Which revision of the Duet do you have? If it's 1.03 or 1.04 then the cause may be a blown fuse.
        Mklein23 1 Reply Last reply Reply Quote 0
        • Mklein23
          Mklein23 @dc42 last edited by
          @dc42 im not sure, I bought the board on March 10th of this year.
            The PCB revision is marked on the top side of the Duet. If it's 1.03 then there will be a blade fuse and you should look at https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Blade_fuses.
            • Mklein23
              I checked the fuse under a microscope and it is in fact burned out. Will replacing that fuse fix my problem?
                dc42 administrators @Mklein23 last edited by
                @mklein23 said in All my fans have stopped working:
                That depends on what caused the fuse to burn out. Check for shorts in the fan wiring.
