Configuring idle timeout
Currently there's a way for motors to drop current if no moves occur for awhile. Is there a way to run other Gcode when this idle timeout triggers? I'd like to set up some stuff to automatically turn off other things with a timeout.
Currently there isn't. What else did you want to do when the idle timeout triggers?
Well, I'm hoping for an idle timeouts independent of the motor one.
For example, a standby routine after a half-hour of being idle:
; After 30 minutes of inactivity, send the effector to the rear right corner ; and power off, waiting for temperatures to cool. Mxxx I"Standby" S1800 P"G1 X225 Y225 F3600; M81 S1"
Where
I
is used for a timeout label,S
specifies the time in seconds for the idle timeout, andP
specifies some commands (or a single command invoking a macro) to run. -
I've added this to the firmware wishlist.
thank you!
@Jacoby6000 add some beeps to that routine. You would not want to have your fingers around troubleshooting some mechanical issues at that time
+1 switching printer to idle and completely off later will be very appreciated indeed
optional audio (let say 1 min before and 10 sec before ) notice will add safety
