    M571 to turn on Fan 0 everytime the extruder is started.
    • Danny Defelici
      Danny Defelici last edited by
      I'm trying to configure M571 to turn on Fan 0 everytime the extruder is started.
      I've tried this but I think I'm missing something
      M571 P0 F200 S255
      I'm trying to trip a 5-volt small solenoid every time the extruder comes on.
      Danny
        The P parameter is the logical pin number, not the fan number. See https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers. Note, to use a heater or fan pin you have to make the pin free first before M571 can use it.
        • Danny Defelici
          is this correct
          M106 P20 I-1
          M571 P20 F200 S255
            No, it should be M106 P0 I-1 because it is fan 0 that you are disabling. The M571 command is correct.
            Danny Defelici 1 Reply Last reply Reply Quote 0
            • Danny Defelici
              Danny Defelici @dc42 last edited by
              I'm using 2 extruders and I need to lift my second extruder when it's not printing. So I'm trying to use.
              M571
              How do I address the second extruder using this command
