    Problem with powering on with M80
    773
    • dek
      dek last edited by
      I'm trying to have the printer power on when I send it a file to print from Cura with the DuetRRF plugin. I'm sending the M80 in the start script but this doesn't work because I'm guessing it needs to power on earlier than this in the printing process. Is there any way of trigger the M80 when the printer receives a print command?
      • Veti
        Veti last edited by
        Did you open the gcode and look where the M80 command is?
        in slicer i have it as the first command in start g code and its working fine.
          You might need to include a G4 delay command after the M80 command to give the stepper drivers time to power up.
          • dek
            dek last edited by
            I have the start script stored on the duet and referencing it in the slicer with "M98 P/macros/Scripts/start.g"
            And start.g starts with:
            M80 ; Power On
            G4 S5 ; Dwell for 5 seconds
            But the printer doesn't even power up. However, sending the M80 command in the G-code console works.
            • Veti
              Veti last edited by
              try adding the m80 directly
                dc42 administrators @dek last edited by
                @dek said in Problem with powering on with M80:
                M80 ; Power On
                Is the M98 command right at the start of the GCode file generated by the slicer? I have a suspicion that if you look, you will find there there are some heating commands before it.
                Have you tried putting the M80 command in file /sys/start.g file instead? That script is run automatically when you start a print from SD card, unless you are using old firmware.
                dek 1 Reply Last reply Reply Quote 0
                • Veti
                  Veti last edited by
                  This is how my printer starts in cura. if you dont include the 104 140 109 cura will generate them before the m80 command.
                  M80
                  M104 S{material_print_temperature_layer_0, 0} ;Start heating extruder
                  M140 S{material_bed_temperature_layer_0, 0} ;Start heating bed
                  M109 S{material_print_temperature_layer_0, 0} ;Wait for extruder to reach temp before proceeding
                  • dek
                    dek @dc42 last edited by
                    @dc42 said in Problem with powering on with M80:
                    M80 ; Power On
                    Yes, this worked! Thank you!
                    As Veti said I think the problem was that Cura generated the commands in the wrong order. By a start.g in the sys directory I can still keep it simple in the slicer. This will make switching between different slicers easier.
                    • Veti
                      Veti last edited by
                      dont forget the M81 S1 in the end code
                        dc42 administrators @Veti last edited by
                        @veti said in Problem with powering on with M80:
                        ...or in stop.g.
