    Make my heated bed magnetic w/ high temp magnet sheet?
    Third-party add-ons
    • mikebridge
      mikebridge last edited by
      Am I overlooking anything thinking I can use something like this: https://www.mcmaster.com/7301t25 (max temp 250F/120C) applied on my aluminum bed to allow me to use the various spring steel flexible build surfaces? Possible concerns w/ thickness variation, and the max temp is around the upper range for bed temps for Nylon & Polycarbonite
      I print primarily ABS @ 110C for first 10 layers, then 100C for subsequent layers.
      375x360x415 CoreXY DuetWifi + Duex5
      24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
      Agniusm 1 Reply Last reply Reply Quote 0
      • mikebridge
        verdict: works very well up to 110C (using it w/ geckotek removable 'hot' build plates). have not tested higher temps.
        • Danal
          Danal last edited by
          FWIW, I recently bought at Prusa i3 Mk3 and the sprint steel bed is one of my very favorite features of this printer. So do give it a try... springy fantastic!
          • Agniusm
            Agniusm @mikebridge last edited by
            @mikebridge now tell me where i can get these in europe!
