Solved Slow upload
I'm getting about 20Kb/sec uploading files. I tried a different SD card formatted at Fat32 64k as suggested in a post some months ago. that didn't help. Below is the M122 from right after the upload. My Duet sits 2 feet from my router.
Any recent development that may help here?
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3S0-7J9FJ-3SD6P-KS57F
Used output buffers: 3 of 20 (8 max)
Static ram: 28380
Dynamic ram: 95872 of which 16 recycled
Exception stack ram used: 332
Never used ram: 6472
Task NETWORK ready, free stack 396
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3648
Last reset 00:27:13 ago, cause: power up
Last software reset at 2018-11-21 16:39, reason: User, spinning module GCodes, available RAM 6380 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 117.2ms
MCU temperature: min 23.2, current 34.6, max 34.9
Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0
Date/time: 2018-11-26 15:50:32
Slowest loop: 35.01ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 169.95ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed to get WiFi status
not sure why it failed getting wifi status (maybe a clue)
next m122 it did get status:
Failed messages: pending 1, notready 0, noresp 0
WiFi firmware version 1.21
WiFi MAC address
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 15024
WiFi IP address 192.168.1.177
WiFi signal strength -26dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
=== Expansion ===I tried to see if ftp was any different but with FileZilla I can't seem to upload a file to /gcodes.
- WiFi -
The SD card write time looks very slow. I suggest you get a new SD card, preferably a trusted brand, either class 4 or class 10. Format it with 64kb clusters if you can, or 32kb clusters if you can't.
@core3d-tech said in Slow upload:
You need to configure FileZilla to use only one connection when uploading files. It defaults to 2.
@dc42 The cards are Sandisk Ultra but without class indicator so probably old. I'll get a new one. Wish Duet would come with less inferior sd card. I will try the Filezilla setting as well. As soon as I have the cards I'll update. Thx!!
I would have expected Sandisk ones to work well, assuming they are genuine. But if they have no class indicator, that's very odd. Did they come from us, or somewhere else?
Last time I tested the cards supplied with the Duet, they worked well, upload speed was within about 20% of the top ones I tested. But perhaps we have changed supplier since then.
The card it came with was no brand 4GB class 4
I have the same unbranded 4GB card that came with Duet (this year) and it is fast.
A big file (5MB) starts at 700KB/sec and drops to 580KB/sec towards the end. That's fast enough for me, didn't bother to insert any of my other cards. -
@sigxcpu in that case I don't know what is going on. I did receive it this year; black micro SD Class 4 (C04G taiwan). I just tried speedsmart on my ipad connected to same wifi and got 16Mb upload speed.
Your iPad will be using a large cache, so it's measuring the WiFi speed not the SD card speed, unless you upload a truly huge file e.g. size at least 10x the amount of RAM in your iPad.
@dc42 Got it, it was more to check that my router wasn't crapping out. I have some class 10 cards coming my way and I'll will post any updates on any progress.
Hey, just chiming in to say I'm having the same issue all of a sudden (I've had my board for around half a year now and I believe this issue started a day or two ago).
Uploads are fine for an instant-- it says it's hovering around 3 - 5Mb/s-- but then immediately crashes down to around 60 Kib/s.
Uploading a 3 MB file took long enough for me to google other peoples' concerns in this forum, find no solutions, and then register an account and start typing up this reply before the file finished uploading.
I've already tried reformatting my SD card with 64k clusters but no success; same behavior as before.
Running M122 command immediately after upload gives the following data for my SD card:
"SD card 0 detected, interface speed: 20.0MBytes/sec
SD card longest block write time: 184.6ms"Any thoughts/suggestions?
Just uploaded a big file (15.6MB) and got this:
SD card longest block write time: 660.7ms, max retries 0
M39 reports:
SD card in slot 0: capacity 15.93Gb, free space 15.89Gb, speed 20.00MBytes/sec, cluster size 64kb
The upload hovered between 500 and 700 KB/sec. I am not sure that value is so relevant.
I've seen short stalls un upload, but then it resumed at the mentioned speed.
Maybe some cards have more stalls, so the total speed is reduced much more?
I need to mention that I've replaced original unbranded Duet card (4GB) with this one (SandDisk UHS something) after reading this topic and the old one was a little better. This one has a pause when it starts the upload then continues fine.
@sigxcpu said in Slow upload:
I haven't seen a block write time as long as that before. Does M122 show any SD card retries?
As SD cards get older, they reach the point at which some of the storage on the card has been written several times, and they start to do wear levelling. This involves copying blocks of data around and/or writing data multiple times. The result is that some write operations start to take much longer.
I just received my brand new SandDisk 32Gb UHS-I class 10, so here's my latest. It's not good news
Upload speed out of box: ~110KiB/s (not as slow as before but hardly impressive)
M122
Used output buffers: 1 of 20 (13 max)
Static ram: 28380
Task MAIN running, free stack 3568
Last reset 00:03:37 ago, cause: power up
Last software reset at 2018-11-30 14:12, reason: User, spinning module GCodes, available RAM 6472 bytes (slot 0)
Error status: 0
SD card longest block write time: 34.7ms
MCU temperature: min 23.9, current 31.5, max 31.6
Supply voltage: min 22.2, current 24.2, max 24.8, under voltage events: 0, over voltage events: 0
Date/time: 2018-11-30 15:04:37
Slowest loop: 4.36ms; fastest: 0.07ms
Segments left: 0
=== Network ===
Slowest loop: 109.64ms; fastest: 0.01ms
WiFi MAC address 84:f3:eb:41:95:b3
WiFi flash size 4194304, free heap 15192
WiFi signal strength -27dBm, reconnections 0, sleep mode modem
=== Expansion ===
Next I reformatted at with FAT32 64Kb (not sure what it was before) Uploaded the same file
Speed down to below 100KiB/SM122
Static ram: 28380
Last reset 00:02:48 ago, cause: power up
Error status: 0
SD card longest block write time: 36.6ms
MCU temperature: min 27.7, current 32.9, max 32.9
Date/time: 2018-11-30 15:10:19
Slowest loop: 5.26ms; fastest: 0.07ms
Segments left: 0
=== Network ===
Slowest loop: 111.20ms; fastest: 0.01ms
WiFi flash size 4194304, free heap 15168
WiFi signal strength -28dBm, reconnections 0, sleep mode modem
Failed to request ESP stats
=== Expansion ===
I'm not really sure this is a card issue
M39
SD card in slot 0: capacity 31.91Gb, free space 31.89Gb, speed 20.00MBytes/sec, cluster size 64kb - WiFi -
@core3d-tech Are you using a router that supports both 2.4Ghz and 5Ghz networks? If you can, try only enabling the 2.4Ghz network and test again.
Does the router have any traffic control functions enabled?
Can you disable IPv6 on the router and sending PC?
@phaedrux turned off 5Ghz, turned off Qos (only traffic control I'm aware of), turned off ipv6 both on asus as well as network sharing adapter settings. Upload speed still around ~100KiB/s. Did not seem to do the trick
I've been having slow uploads for some time.
The cure for it in my case was to rotate the printer 90 degrees.
2.4 mhz is quite sensitive to antenna orientation and position
Some development here. I just removed my current ASUS router (2 feet away) from the duet and added my NETGEAR router (on that is on the other side of the house, 1 wall, 1 ceiling, 50 feet away).
Upload tripled in speed running over 350KiB/s (still not 600 but much better). Clearly there's something it doesn't like about the ASUS setup.
Asus Router: RT-AC68U
Netgear: R6700 NighthawkM122
Used output buffers: 3 of 20 (9 max)
Static ram: 28380
Task MAIN running, free stack 3584
Last reset 00:08:59 ago, cause: watchdog
Error status: 0
SD card longest block write time: 37.6ms
MCU temperature: min 23.7, current 31.0, max 31.2
Supply voltage: min 0.0, current 24.2, max 25.0, under voltage events: 0, over voltage events: 0
Date/time: 2018-12-01 10:27:43
Slowest loop: 38.37ms; fastest: 0.06ms
Segments left: 0
=== Network ===
Slowest loop: 110.44ms; fastest: 0.01ms
WiFi flash size 4194304, free heap 15008
WiFi signal strength -69dBm, reconnections 0, sleep mode modem
=== Expansion ===
- WiFi -
The sub-optimal aerials on most routers ( so they look nice and neat ) tend to have blindspots in surprising places, multiple aerials can interact and make this worse when close by
Interesting, I am using an Asus DSL-AC68U router and I get 750 to 800kbyes/sec upload speed for a 10Mbyte file. WiFi signal strength is -51dBm.
@dc42 yes especially considering the Netgear that runs faster and is on the other side of the house runs through the ethernet port of my ASUS. Not sure what that means but it seems that it's not a soft traffic throttling setting on the ASUS. I will try the antenna thing mentioned earlier, tomorrow. Bit skeptical about that one
It may also be worthwhile trying a different WiFi channel.
@dc42 just switched back to Asus and tried different channels. before it it was 3, I tried, 2 which had no change, tried channel 4 which got better but still sub 200KiB/s. Tried 7 and again baqd news. Channels do seem to make a difference but still nothing that say, yep fixed it.
Also tried pointing the antennas in different directions (to no avail).
last update on this. My internet was just out and as part of the usual exercise I turned off modem and router and now that everything is back up speed is in the 600s. I have turned off the router before but this time seemed to have done the magic
Just curious, what is the expected network throughput on the Maestro? I get 660KB/sec (I think it's B and not b) so roughly 5mbit. The SD card I have is super fast when plugged into my computer, so just wondering if the network interface on board is the bottleneck or the SD card drive on the board?
