    IR probe leds does not flash at all
    673
    • leonknook
      leonknook last edited by leonknook
      Hello to you all,
      Connected the IR probe version 1.3 to the board (Duet Ethernet) and when powered on there is no flashing of the leds at all.
      I have measured the VCC+ en ground on the little board and there is 3.3v. Also measured if the signal lead is connected to the main board with an ohm meter and that is also fine. The probe does respond to the surface but when probing to all the points, there is no flashing and If got the message "Z probe was not triggered during probing move". Looks like the there is something wrong with the IR-probe board. What can I do. Wires to the probe are quite long around 3 meters.
      kind regards,
      Leon.
        dc42 administrators @leonknook last edited by
        @leonknook said in IR probe leds does not flash at all:
        The probe does respond to the surface...
        In what way?
        • leonknook
          In the control panel there is a distance probe reading like the 465 and 535.
          After I zero the nozzle tip to the buildplate with G92 Z0
          I entered the G30 S-1 after going 5mm up.
          I get a reading of 1.15mm so I asume the sensor is triggering something?
          I remembered I did not connect the board first with USB but ride away using
          the ethernet cable. Could that be the reason for not flashing the led's?
            When you get a reading of about 535 from the sensor, it has triggered and the red LED should be lit. If it isn't lit, then the IR sensor board is faulty.
            • leonknook
              Thanks!, that what I think too. I will go to my supplier.
              • leonknook
                I'm back with a brand-new Duet Ethernet board and a new Ir-sensor. Ir sensor is flashing 4 times when starting up.
                I followed all the instruction several times over here but for some reason it does not work. Constantly getting the message after send "M558 P1 and G31 P500 Z1.0"
                "G30 S-1
                Error: Z probe already triggered at start of probing move"
                Even when sensor is way up like 15 cm.
                Reading is 1000 sensor way up, getting closer and touch the sensor reading 461?!
                sensor lids red when touching
                M119
                Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
                here a piece of my config.g where probably something is wrong
                config.g
                M569 P5 S1 R1 T1 ;Y-as
                M569 P6 S0 R1 T1 ;X-as
                M569 P7 S0 R1 T4 ;Z-as
                M584 X6 Y5 Z7 E3 ; Apply custom drive mapping
                M564 S0 H0
                M350 X8 Y8 Z8 E8 I1 ; Configure microstepping with interpolation
                M92 X125.98 Y125.98 Z500 E495 ; Set steps per mm
                M566 X300 Y300 Z50 E120 ; Set maximum instantaneous speed changes (mm/min)
                M203 X5000 Y5000 Z500 E500 ; Set maximum speeds (mm/min)
                M201 X200 Y200 Z50 E100 ; Set accelerations (mm/s^2)
                M906 X7200 Y7200 Z4000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S50 ; Set idle timeout
                M208 X700 Y400 Z100 S0 ; Set axis maxima
                M574 X1 Y1 Z2 S0 ; Set active low endstops
                M558 P1 I1 H2 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                M557 X60:700 Y60:400 S20 ; Define mesh grid
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool on Thu Oct 04 2018 14:52:24 GMT+0200 (Midden-Europese zomertijd)
                ; Probe the bed at 4 points
                G30 P0 X60 Y60 H0 Z0
                G30 P1 X60 Y400 H0 Z0
                G30 P2 X750 Y400 H0 Z0
                G30 P3 X750 Y60 H0 Z0
                ; homez.g
                ; called to home the Z axis
                G91 ; relative positioning
                G1 Z5 F10 S2 ; lift Z relative to current position
                G1 S1 Z-100 F500 ; move Z down until the endstop is triggered
                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                ;G91 ; relative positioning
                ;G1 S2 Z5 F100 ; lift Z relative to current position
                ;G90 ; absolute positioning
                I hope it is a simple fault. I'm almost there to get this printer working, dealing with the frustration the nozzle has crashed several times into the build plate and the heat brake is broken now 😞
                  Remove the I1 from your M558 command.
                  leonknook 1 Reply Last reply Reply Quote 0
                  • leonknook
                    leonknook @dc42 last edited by leonknook
                    Yes thank you very much that did the job!
                    Instructions followed and they work now.
                    But please hang on with me.
                    I want to set the probing grid but have problems with the Z-homing. The sensor does not respond and the nozzle hits the build plate.
                    Must be something wrong in the homez.g
                    Firmware Electronics: Duet Ethernet 1.02 or later
                    Firmware Version: 2.0(RTOS) (2018-06-05b3)
                    Web Interface Version: 1.19.3
                    M558 P1 H2 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                    G31 P500 X0 Y0 Z0.390 ; Set Z probe trigger value, offset and trigger height
                    ;M557 X60:700 Y60:400 S20 ; Define mesh grid
                    M557 X0:200 Y0:220 S20
                    ; homez.g
                    G92 Z5 ; set Z position to axis minimum (you may want to adjust this)
                    • leonknook
                      Found the solution already by using a typical Homez.g file for a probe.
                      G91 ; relative mode
                      G1 S2 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
                      G90 ; back to absolute mode
                      G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
                      G30 ; lower head, stop when probe triggered and set Z to trigger height
                      Thanks for the help!!
                      Kind regads,
                      Leon
