    Cura Noob, help required
    • Tef9undefined
      Tef9
      Hi There,
      I am using my converted Tevo Little Monster to try Cura, I configured the system as best I could however there is one issue. I am using version 3.6 Ultimaker.
      The printer seems to hover above the bed by about 10cm and attempts to print a large brim. The extruder goes haywire with huge moves but no extrusion and then extrudes backwards?!?
      The part is a 20x20x20 test cube. So why its so large and massively offset I do not know?
      Attached is the Gcode as I am very confused, I did feel it had something to do with G21 or M83. I tried slicing sever cubes (there are 6 in total) and no matter what I changed or configured it seemed to do the same thing. When I load a slic3r file its fine.
      Any help would be appreciated.
      CuraTest6.gcode
      Best regards,
      Andy
        ;FLAVOR:RepRap
        ;TIME:393
        ;Filament used: 1.12226m
        ;Layer height: 0.4
        ;Generated with Cura_SteamEngine 3.6.0
        T0
        M190 S72
        M104 S198
        M109 S198
        M83
        G28
        G21
        ;G32
        G29 S1
        G1 Z50 F1500
        G92 E0
        G91 E8
        It would appear you have a G1 Z50 move in your startup gcode in Cura. That would explain why it's printing in the air.
        G91 E8 isn't a valid command either.
