    G30 S-1 Not Working
    2275
    • ElmoC
      ElmoC last edited by
      Trying to finalize my 1.17c setup and going through the steps in doing the mesh setup. When I give the G30 S-1 command, the bed moves away from the nozzle and then I get an error that the Z probe wasn't triggered. I am using a BL Touch sensor and it is working for homing and with G32. I'm guessing I have something wrong in the config, but not sure what. Here is my config.g file (minus the network stuff)
      [c]G21 ; Work in millimetres
      ; Machine configuration
      M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P4 S1 ; Drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3:5:6 ; Add E1 as a second drive motor for the Z axis
      ; If you use an end stop switch for Z homing, change Z0 to Z1 in the following line,
      ; and see also M558 command later in this file
      M574 X1 Y1 Z0 S0 ; set end stop configuration (X and Y are low end stops active high)
      M667 S1 ; set CoreXY mode
      M906 X1000 Y1000 Z1100 E600 ; Set motor currents (ma)
      M201 X3000 Y3000 Z100 E4000 ; Accelerations (mm/s^2)
      M203 X3000 Y3000 Z400 E3600 ; Maximum speeds (mm/min)
      M566 X600 Y600 Z30 E20 ; Maximum jerk speeds mm/minute
      M208 X323 Y201 Z345 ; set axis maximum (adjust to suit your machine)
      M208 X-8 Y0 Z0 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edges of the bed)
      M92 X100.86 Y100.86 Z389.8 ; set axis steps/mm - Direct
      ; Z probe
      M558 P4 X0 Y0 Z1 H5 F100 T2000 ; Switch for Z probe.
      ; Move 5mm between probes.
      ; Probe speed 100mm/min.
      ; Travel speed 2000mm/min.
      G31 X50 Y36 Z1.65 P5 ; Set the probe height and threshold (put your own values here)
      ; Probe is to the right and behind nozzle
      ; Configure pins for the BL Touch
      M307 H5 A-1 C-1 D-1 ; Using heater 5
      M280 P5 S90 I1 ; Make sure it starts retracted.
      ; Tool definition
      M563 P0 D0 H1 ; Define tool 0 - Using drive 0 (Extruder 0) and heater 1
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      M92 E417 ; Set extruder steps per mm - Titan Extruder
      ; Thermistors and heaters
      ; You can also use S and B parameters to define the parameters of the thermistors you are using
      M305 P0 T100000 R4700 B4540 ; Bed
      M305 P1 T100000 R4700 B4700 ; Hot End
      ; Bed M307 values generated from running M307 H0 D30 then M303 H0 P0.2 S90 and reading the results with M307 H0
      ;Heater 0 model: gain 312.8, time constant 651.2, dead time 11.8, max PWM 1.00, in use: yes, mode: PID
      M307 H0 A312.8 C651.2 D11.8 B0
      ; Hot End M307 values generated from running M303 H1 P0.3 S200 and reading the results with M307 H1
      ;Heater 1 model: gain 464.0, time constant 262.4, dead time 6.5, max PWM 1.00, in use: yes, mode: PID
      M307 H1 A464.0 C262.4 D6.5 B0
      M570 S180
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0 ; Axis compensation here
      M106 P1 S0
      T0[/c]
      • DjDemonD
        DjDemonD last edited by
        Have you got your z motor/s turning the wrong way, so the z axis descends when it should raise?
        www.precisionpiezo.co.uk
        • ElmoC
          Z axis is working fine. I can do the G32 bed.g leveling and printing with no problems. It is only the G30 command that is giving me problems.
          • InSanity
            InSanity last edited by
            Make sure your config.override file isn't messing with the P5 value for G31. I had that problem.
            Jeff
            Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
            • DjDemonD
              +1 for that I've had a few issues lately with config_override.g causing odd behaviours, I delete it periodically and copy the values back into config.g and re-calibrate.
              • Merlin
                Merlin last edited by
                I do not have an config.override.g that I am aware of but G30 S-1 is also causing me problems.
                Every time I use the paper test to set G92 Z0 and then raise the head 5mm
                G30 S-1 gives confusing information
                e.g. top right hand display shows Z= 2.92 but G-code console reports "Stopped at height of 1.876mm"
                Auto calibrate will stabilise at 0.015 but G29 bed levelling will then show a map with every point shown as negative!?
                homedelta.g looks fine as I have 250mm upright members on my "Big Delta" variant. (see below)
                Any none any ideas?
                ; Homing file for RepRapFirmware on Kossel
                G91 ;use relative positioning
                G1 S1 X250 Y250 Z250 F2500 ;move carriage up to ENDSTOP,
                G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
                G1 S1 X4 Y4 Z4 F250 ; move slowly up 4mm, stop at the endstops
                G1 Z-5 F2000 ; down a few mm so that we can centre the head
                G90 ; back to absolute positioning
                G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate
                  If the trigger height of the BLTouch is greater than 5mm then you will need to raise the nozzle higher than 5mm before sending G30 S-1. Try 10mm or 20mm.
                  The displayed trigger height and the Z height won't match if bed compensation is active, so it's best to measure the trigger height with bed compensation disabled.
                  • Merlin
                    thanks .
                    Also just realised my homealldelta.g was rubbish, as my upright member is 750mm not 250mm 😞
                    (must take it with more water in future)
                    • ElmoC
                      Dropping Z to 10 before the G30 fixed it.
                      • ElmoC
                        Well, while I did get it to work a couple times, when I went back and performed the steps here https://duet3d.com/wiki/Using_mesh_bed_compensation, the bed only moves away from the nozzle. I tried Z at 5, 10,15, and 20, all with the same results. 😞
                        EDIT: I restarted the printer and homed all axis. I then moved Z to 10, deployed the probe, and tried G30 S-1 again. This time it worked. So one of those commands in the steps is causing the issue. Will see if I can figure out which one.
                        EDIT 2: It seems the problem is with the M208 Z-3 command. This is setting the maximum Z travel to -3. I believe the command should be M208 Z-3 S1 to change the minimum Z travel.
                          I'm glad you worked it out.
