    USB Power Only
    • Cocopufft
      Cocopufft last edited by
      I've been working on getting my printer up and running and managed to get five prints, but when I went to turn the printer on again I only get one blue light. I unplugged everything with the same result - one blue light nothing else. I then removed the board as the USB plug isn't easily accessible, and I see the logic lights and am able to connect to DWC. I've been following the wiring guide religiously, and I did not mess with any wires between it working from 24v and it not. Any ideas?
        Check that the I_5V_EN jumper is still in place, disconnect everything from the Duet except VIN power, and make sure that it isn't sitting on a conductive surface. If you still get only the blue LED lit up, please ask for your Duet to be replaced under warranty.
