SOLVED Slow WiFi upload
I'm also experiencing slow WiFi upload; already changed the SD card and that did not solve the problem. Upload speed drop after split second to <10 KiB/s... According to my router:
Wireless LAN properties (2.4 GHz)
Signal Strength-46 dBm
max. data rate possible72 / 72 Mbit/s
Current throughput52 / 54 Mbit/sM122 command returns:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6JTD8-3SJ6S-TZ8NH
Used output buffers: 4 of 20 (18 max)
Static ram: 28476
Dynamic ram: 96248 of which 16 recycled
Exception stack ram used: 276
Never used ram: 6056
Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3508)
Owned mutexes:
Last reset 00:01:45 ago, cause: software
Last software reset at 2018-12-01 22:37, reason: User, spinning module GCodes, available RAM 6056 bytes (slot 0)
Error status: 0
Free file entries: 9
SD card longest block write time: 5.3ms, max retries 0
MCU temperature: min 36.4, current 36.6, max 36.8
Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
Date/time: 2018-12-01 22:38:59
Slowest loop: 7.06ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 167.25ms; fastest: 0.08ms
Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 84:f3:eb:83:38:2c
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 16440
WiFi IP address 192.168.178.53
WiFi signal strength -59dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
=== Expansion ===
Also tried to adjust orientation of the board, but that did not help.
Board is HW 1.04v. Installed the board today, but with this speed it is actually not usable (and not worth the money..). I hope it can be fixed! Looking forward to hearing from you
- WiFi -
Today I switched from one router to another (Asus to Netgear) and the difference was considerable. 100KiB/s for the asus 2 feet away from Duet to 400KiB/s for the netgear on the other side of the house. I don't know if there's any setting on the Asus that are different from netgear (or if it's brand or age). Switching cards did nothing for me either.
So, I did some more testing. Different router (separate wifi network) I was getting OK rate uploading a file using my phone. Connecting this router in LAN - Wifi bridge and uploading via my PC again did result in very slow rates. With my laptop (LAN or WiFi connection) I can achieve OK data rates with both my default router and the separate one.
Conclusion: my PC is the issue (which is connected via LAN to my router)... I will debug some more to find the issue.. -
Got it! Using wireshark I saw a lot of traffic from my PC to my server --> It was running a backup.. Even though I also rebooted the PC today it did not stop the backup. Also I'm not sure exactly when the backup was started, it must have been running since yesterday morning..
To conclude it had nothing to do with duet3d WiFi. Sorry for the inconvenience, now time for some more printing with this awesome board
@jasper said in Slow WiFi upload:
Glad you got it sorted. Can you now mark this thread as "Solved".
