    Babystepping/Z-offset problem squeeched first Layers
    • PuddingBaer91undefined
      PuddingBaer91
      i often use the Feature "z-Offset" in duet web control to lower the nozzle by 0.05 steps.
      I am using a core xy machine where postive z is going downwards (to earth)
      If i control the machine with duet web control the print bed will going downwards if i press a +X Value button. So it works the right way.
      If i move to bed with -0.005 closer to the nozzle (negative z) it will do this. But at z height it will Show this amount as a positive value, why??
      If i move the bed to -0.4 for example the second layer will be extremly squeeched because the second layer will not go to 0.6 (for 0.2 layer height) it will stay at -0.4, why?? Because of this Problem the function is not really useful 😞
      Thank you for your help
        Which firmware version are you using?
          PuddingBaer91
          I am using firmware version 2.02RC2 (RTOS) (2018-09-07b2)
