    Change Z-babystepping to Y-babystepping for Belt printers.
    Firmware wishlist
    1199
    • NAK_3D
      NAK_3D last edited by
      Would it be possible or is there a way to change Z-babystepping to Y-babystepping? I'm building a belt printer and the distance from the print surface is controlled by the Y-axis on a belt printer.
      Thanks
      NAK_3D
        The M290 command currently only supports Z babystepping, but it would be possible to extend it to support other axes as well.
        NAK_3D 2 Replies Last reply Reply Quote 0
        • bot
          bot last edited by bot
          I could see this feature being useful for fine-tuning the alignment of tools on an IDEX printer.
          On that note: does babystepping function on a per-tool basis, or is it an augmentation of a single "machine coordinate system?"
          *not actually a robot
            dc42 administrators @bot last edited by
            @bot said in Change Z-babystepping to Y-babystepping for Belt printers.:
            It applies to all tools. I guess we could add a command to shift the babystepping offsets into the offsets of the current tool and clear the babystepping offsets, but I'm not sure whether that would be useful more generally.
            timcurtis67 bot 2 Replies Last reply Reply Quote 0
            • timcurtis67
              timcurtis67 @dc42 last edited by
              @dc42 said in Change Z-babystepping to Y-babystepping for Belt printers.:
              Personally I would prefer to alter the X and or Y with a G10 offset in my config file or manually. Once I change hotends I always get my offsets dialed in before doing any real prints. Then once it is set I haven't had any alignment issues.
              Just my opinion on this, nothing more.
              • bot
                bot @dc42 last edited by
                Hmm, maybe a good solution would be to simply allow a modifier in the babystepping GCODE to tell the printer to apply it to only one specific tool?
                @timcurtis67 said in Change Z-babystepping to Y-babystepping for Belt printers.:
                I agree. I could only picture using babystepping to discover the best offset to apply manually/permanently.
                • NAK_3D
                  NAK_3D @dc42 last edited by
                  @dc42 That would make dialing in a belt printer much easier... I would be more than happy to test the feature should you implement the ability to baby step the y-axis.
                  • NAK_3D
                    @dc42 I was just on a live stream with Scott Lahteine from Marlin.. He told me that with Marlin if you enable "Babystep_XY" it will let you babystep all axis.. I know currently this feature is not supported by RepRap.. Any chance you guys have the pull to get this feature supported as well as I believe this would resolve my problem.. Thanks
                      Please remind me again about a week from now. Just to be clear, do you need to babystep Y while the print is running, or would you do it before starting the print?
                      • NAK_3D
                        @dc42 I will do my best to remember to remind you in a week... As for when I would use babystepping, both would be nice but I see it being used more during the print for my application.
                          dc42 administrators @NAK_3D last edited by
                          @nak_3d, wouldn't babystepping during a print give you a Y layer shift as well as adjusting the Z height?
                          NAK_3D 1 Reply Last reply Reply Quote 0
                          • NAK_3D
                            @dc42 I suppose you might see a slight shift but I'm wanting to be able to adjust for flow variances that effect first layer adhesion..so I'd only be using it to make small adjustment in the first few layers... If you've never seen a belt printer running it may be hard to grasp, but on each layer only 1 line moving across the x-axis touches the bed.. the z-axis moves horizontally away from the nozzle while the y-axis varies the distance from the bed moving on a 45 degree angle.. So the only way to compensate for bed adhesion is to slightly adjust the Y axis.. Hope this all makes sense...
                            • NAK_3D
                              @dc42 This is your friendly reminder one week later.. 😉
                                Thanks for the reminder. Can you confirm that your machine uses a single Y motor, that affects nothing other than the Y position?
                                • NAK_3D
                                  @dc42 Its a CoreXY design.. I do believe two motors have to run to go a single direction.
                                    @nak_3d said in Change Z-babystepping to Y-babystepping for Belt printers.:
                                    That complicates things, if you want the babystepping to work quickly.
                                    I've implemented changes to the M290 command in my latest internal build to allow any axis to be baby stepped. Currently it will only attempt to apply baby stepping to existing moves in the queue for the Z axis. So Y baby stepping will work on a CoreXY machine, but you will need to wait for existing moves in the queue to complete before it takes effect.
