    Ender 3 Duet WiFi and Maestro drill guides
    Example setups and prints
    • Agniusm
      Agniusm last edited by Agniusm
      I have modified my Ender 3 printer for duet boards. I have included drill and cut guides for wifi and maestro to be fitted into original enclosure. You will need drill, 2mm drill bit, hacksaw or jigsaw for metal, a file to smooth out roughness.
      https://www.thingiverse.com/thing:3260958
      For LCD you will need additional 10 way cable and cut out slots on LCD's EXP1 and EXP2 connectors to fit cables reversed.
      For duet its a tight fit. Wi-Fi needs bed connector to be bewildered and soldered in reversed.
      • 3dmntbighker
        3dmntbighker last edited by
        I did the board this way.
        https://www.thingiverse.com/thing:3197999
        Nice work
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
