    Solved New board but no working WiFi.
    1545
    • AnWi
      AnWi last edited by
      I got my second Diet 2 Wifi two days ago but on the new card WiFi circuit refuse to start. I have been asked to do some fault findings:
      When plugging in USB cable from adapter I get 3 LEDs
      Red at the USB connector
      Green for 3.3 Volt
      Red for 5V
      As expected.
      I have compared alla jumper settings with my working Duet 2 WiFi module and the are equal but when I power on the new board the WiFi module gives a short blue flash and nothing more. Dead quiet.
      Pronterface works fine. I have flashed the latest (same) firmware again. No change. Flashed DuetWifiServer( 1.21).bin (and yes: I renamed it). Still no progress
      Renamed www- directory and created a "new" www with the latest DuetWebControl (1.22.5)
      This morning I checked all pins of the WiFi module with a DWM
      Left row:
      3.3V = 3.3V
      MOSI = Low
      MISO = data
      SPCK = Hi
      Espen = Low
      EspRst = Hi
      Right row:
      Gnd = Gnd
      NpSco = Hi
      Edr = Hi
      Iq5 = data
      Tx = Hi
      Rx = High but gets data about once/second
      I have swapped the SD-card between the 1st Duet 2 Wifi. Both SD-card works there so my configuration should be fine. NONE of the SD card starts the WiFi unit on my new Duet 2 Wifi card.
      Please help. I get the impression that the bord isn't working.
      Mr Anders Wikström
      Sweden
        What response do you get if you send M552 S0 (e.g. from USB) to put the WiFi module into Idle mode? If necessary, send M552 with no parameters after that.
        If it reports "WiFi module is idle", what response do you get if you try to use M587 to set your access point details?
        • AnWi
          AnWi last edited by
          @dc42 said in New board but no working WiFi.:
          M587
          M587
          [ERROR] Printer is not online.
          WiFi reported error: no known networks found
          WiFi module is idle
          But!!! It does not turn blue or blinking
          The configuration is working! When I put the memory card in my first Duet2 WiFi it does connect to my WiFi and
          If I put the memory card from my first Duet2 WiFi and put it in this one there is NO WiFi
            Try sending the M587 command again. Pronterface reported that it wasn't connected to the printer, so it never sent the command.
            • AnWi
              AnWi last edited by
              M587
              M587
              SENDING:M587
              M587: Failed to retrieve network list
              Error retrieving WiFi status message: bad reply format version
              [ERROR] Error retrieving WiFi status message: bad reply format version
              /sys/config.g
              ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 16 2018 12:33:31 GMT+0100 (centraleuropeisk normaltid)
              M550 P"RoboNaviCut CNC" ; Set machine name
              M552 S1 ; Enable network
              M587 S"RoboNaviCut" P"MyWiFiPSW" ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
              M92 X80.00 Y80.00 Z4000.00 ; Set steps per mm
              M566 X900.00 Y900.00 Z12.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 ; Set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 ; Set accelerations (mm/s^2)
              M906 X800.00 Y800.00 Z800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X850 Y850 Z200 S0 ; Set axis maxima
              M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
              M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
              M557 X15:835 Y15:195 S20 ; Define mesh grid
              M140 H-1 ; Disable heated bed
              M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              • aidar
                aidar last edited by
                Hi.
                I guess your M552 S1 command should be after M587. So it should looks like :
                M552 S0
                M552 S1
                  @anwi said in New board but no working WiFi.:
                  That indicates that the versions of DuetWiFiServer and the the Duet main firmware are out of step. If you send M115, what main firmware version does it report?
                  • AnWi
                    AnWi last edited by
                    Thank you very, very much!!! WiFi has started and is working now.
                    You made my day 🙂
                    Connecting...
                    ok B:2000.0 /0.0
                    Printer is now online.
                    ok B:2000.0 /0.0
                    M552 S0
                    SENDING:M552 S0
                    WiFi module started
                    ok B:2000.0 /0.0
                    M587 S"RoboNaviCut" P"CutMyGrass"
                    SENDING:M587 S"RoboNaviCut" P"passwd"
                    ok B:2000.0 /0.0
                    M552 S1
                    SENDING:M552 S1
                    ok B:2000.0 /0.0
                    WiFi module is connected to access point RoboNaviCut, IP address 192.168.154.20
                    ok B:2000.0 /0.0
                    M115
                    SENDING:M115
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02RC5(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-11-28b1
                    ok B:2000.0 /0.0
                    ok B:2000.0 /0.0
