    Random stop mid-print
    • camason
      camason last edited by
      I'm having an intermittent issue which I'm struggling to diagnose. It has happened randomly over the past few weeks.
      The printer will suddenly stop moving, the web interface disconnects, and the BLTouch sensor deploys (hitting the part a couple of times, and then flashing red as it can't extend fully). The fans all remain on. It's as if an emergency-stop was triggered.
      There seems to be nothing specific I can do to replicate it. I have to power-cycle the printer to get a connection.
      I tried to run M122 but accidentally typed M112 first, so unsure if this diagnostic output is correct. I have not yet attempted updating firmware / web interface. I've only started experiencing this problem recently (past few weeks).
      Used output buffers: 3 of 32 (23 max)
      RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
      Board ID: 08DDM-9FAM2-LW4S4-6J9D6-3SD6J-12S7X
      Static ram used: 16152
      Dynamic ram used: 100408
      Recycled dynamic ram: 2224
      Stack ram used: 1224 current, 4512 maximum
      Never used ram: 7776
      Last reset 00:00:28 ago, cause: power up
      Last software reset at 2018-11-27 14:44, reason: User, spinning module GCodes, available RAM 7888 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 35.2, current 35.4, max 35.7
      Supply voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0, over voltage events: 0
      Date/time: 2018-12-07 10:00:25
      Slowest main loop (seconds): 0.172815; fastest: 0.000112
      MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: mesh
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address 60:01:94:73:61:88
      WiFi Vcc 3.29, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 15992
      WiFi IP address 192.168.0.18
      WiFi signal strength -36dBm, reconnections 0, sleep mode modem
      Socket states: 2 0 0 0 0 0 0 0
      === Expansion ===
      Thank you,
        I suggest you upgrade the firmware to version 2.01. If it happens again, run M122 again without resetting the printer or running M122 first.
        • camason
          Thanks dc42.
          I may have found the culprit - a loose connector on the 230v in supply (mid-cable connector).
          I'll re-wire and also update firmware.
