Unexpected token i in JSON at position 148
  • Hi all.
    Today I uploaded a bad GCode to Duet3D and when I like enter at "G-Code Files" interfaz shows this message:
    Can you explain what is the solution? 😞
    Press F12 in your browser to open the developer console. It should show the complete unparsable response; please post that here.
  • Work it! M30 for delete GCode archive.
    It was damaged 😕
    @mc_kanan said in Unexpected token i in JSON at position 148:
    It was damaged 😕
    Can you explain that in more detail? Even if there was something wrong with a GCode archive file, I'd still like to fix whatever was causing the error message.
  • When creating the GCode file in Simplify the last layers I created them with a very large plane that had never happened to me before.
    By putting the GCode file generated from that piece and trying to enter the files on the board, I got the error. Using the M30 command and the file name was solved. (And luckily ...).
    It allowed me to reconnect with the board (I have the wifi version) and enter the rest of the options, but once I tried to access the saved GCode files again, it was disconnected and the error came out again.
