    Duet Panel v3 update firmware / Unknown USB Device
    Firmware installation
    • tech
      tech last edited by
      here is my problem, I tried to update the 1.21.1 @ 1.22 frimware and here is the error that appears after pressing Erase and Reset ...Unknown USB Device (Device Descriptor Request Failed).
      Is there a way to solve this problem?
      Thanks
      Chris
      • Jacotheron
        Jacotheron last edited by
        Do you have Bossa installed?
        After erase and reset, it should show up as a Bossa device under the Device Manager.
          dc42 administrators @tech last edited by dc42
          @grenierc said in Duet Panel v3 update firmware / Unknown USB Device:
          Thanks
          Chris
          I used to get that message a lot, when I connected Duets to Windows 10 via a USB hub. Switching to another port on the hub fixed it. When I ran out of ports on the hub, sometimes disconnecting and reconnecting the hub would get all the ports working again. If not then I would have to reboot Windows.
          I switched to a different make of USB hub and the problem went away.
