SOLVED E1 reports no filament every time i connect
Hi there,
today i hooked up my filament sensor and it works just fine with the first try
If i push the filamanet out of the sensor it will pause the print and show me the message: "E1 reports no filament"
Only thing i noticed: Every time i connect via the webcontrol interface i get the message: "E1 reports no filament" The print does not pause!
Filament is not empty and the print just continue, it's only a wrong message here.
My config: (Connected the sensor to E1 endstop, the red led lights if sensor is not triggered)
M591 D1 P1 C4 S1
M581 E1 S0 T1Is there something wrong with my config or is it just a bug/feature?
My duet data:
Firmware Version: 2.02RC5(RTOS) (2018-11-28b1)
WiFi Server Version: 1.21
Web Interface Version: 1.22.5Thank you for help
When you reconnect the web interface, depending on what other devices running DWC you have or had connected previously, the last message that was reported may be repeated. I suspect that is what has happened.
thank you very much. I can confirm it was only a repeated message. It works very well. I LIKE MY DUET
