    Solved - Corrupt SD - Reflash a new card?
    Firmware installation
    • Alex.cr
      Alex.cr last edited by Alex.cr
      All,
      HAving a few issues. After not running one of my printers for awhile I tried booting it up(Duetwifi) and had all sorts of issues getting it reconnected to my network. I pulled the SD card and used my PC to view the folder structure, its telling me /sys and /www are "corrupt and unreadable" or along those lines.
      I reflashed the whole firmware using the wiki recovering #3 suggestion and was able to get the firmware to boot. Now the DWC works but I cannot upload and new files to print. It is telling me the SD card is full.
      I am trying to flash a new 16GB card with firmware but can't find a solid way to do this. I tried to load the firmware on using SAM-BA but it does not build the file structure for me to put the DWC files and WIFIserver files into.
      Am I just missing something very simple? I tried searching around on the forum but couldn't find anything similar. I was a bit surprised no one has had similar issues.
      Any help is appreciated! Thanks.
      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        Check this out: https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure
        The folder structure can be downloaded there and copied over to the SD card.
        The firmware is flashed onto the Duet board itself, the SD card just contains files.
        • Alex.cr
          Thanks man! that solves my issue. I should have known that... I figured it was easy.
