    How to submit code changes for consideration
    Firmware developers
    750
    • MichaelM
      MichaelM last edited by
      I modified the PanelDue firmware to have a "WiFi Settings" dialog that allows the user to enter the SSID and password for their network. When they press Enter the specified SSID and Password is embeded in a M587 command. The intent is to make it easier for an end user to configure the WiFi settings of the DuetWiFi.
      I would like to submit these changes for consideration to be added to the root code.
      How do I go about doing this?
      Thanks,
      Mike
      • gtj0
        gtj0 last edited by
        Your best bet is to submit a pull request at
        https://github.com/dc42/PanelDueFirmware
        • MichaelM
          The Pull request button is disabled. I suspect since I do not have write access? Or maybe I need to make a branch first?
          • MichaelM
            I made progress. Should I create a fork and upload to the fork?
            • MichaelM
              I think I submitted a pull request. It would be from MichaelM4.
                Thanks, I'll take a look at it when I start work on the next major PanelDueFirmware release.
                • MichaelM
                  Did you find and look over the code changes I submitted?
                  Thanks,
                  Mike
                    I'm sorry, I can't see your pull request at https://github.com/dc42/PanelDueFirmware/pulls.
                    • MichaelM
                      I must have done it wrong. You can see the code here
                      https://github.com/MichaelM4/PanelDueFirmware
