    Robo3d AUTOLEVEL Not Working
    1369
    • sleepless
      sleepless last edited by
      Recently my robo r1 plus stopped doing the autolevel before a print, and I am not sure why. Perhaps I accidentaly deleted the proper scripts for the gcode in simplify3d? Here is a copy of my starting script
      G28 ; home all axes
      G29 ; probe the bed
      G1 Z5 F5000 ; lift nozzle
      M109 S[extruder0_temperature] ; set the extruder temp and wait
      G1 X15 Y0 ; move to begin wipe
      G1 X20 Z0 F4800 ; wipe
      Please let me know if you need anymore information to help troubleshoot this.
      Thanks and look forward to your repsonse
        When you run that script, does the G29 bed probing operation complete successfully? Do you get any error messages such as "Error: Z probe was not triggered during probing"?
        You can also run M122 after probing and check what the diagnostic reports says for "Bed compensation in use:".
        • sleepless
          I was getting the reading that the z probe was already triggered for g29 it doesnt not go through autolevel sequence. It used to say the z probe was triggered and continue to go through auto level and everything was working well. Not sure what got changed.
            So is it working now? If it isn't working, what error messages are reported?
            sleepless 1 Reply Last reply Reply Quote 0
            • sleepless
              sleepless @dc42 last edited by
              @dc42 i am recieving the z probe error, and it will not go through the bed probing when i send g29 seems probe was already triggered? Not sure what to do
              • sleepless
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 16:32:40 GMT-0700 (Pacific Daylight Time)
                G28 ;
                ; Probe the bed at 4 points
                G30 P0 X15 Y15 H0 Z-99999
                G30 P1 X15 Y239 H0 Z-99999
                G30 P2 X215 Y239 H0 Z-99999
                G30 P3 X215 Y15 H0 Z-99999 S2
                G29 ;
                • sleepless
                  ; homez.g
                  ; called to home the Z axis
                  ; generated by RepRapFirmware Configuration Tool on Tue Oct 30 2018 18:50:03 GMT+0800 (中国标准时间)
                  G91 ; relative positioning
                  G1 Z5 F4000 S2 ; lift Z relative to current position
                  G90 ; absolute positioning
                  G1 X25 Y25 F4000 ; go to first probe point
                  ;G91 ; relative positioning
                  ;G1 S2 Z5 F1000 ; lift Z relative to current position
                  ;G90 ; absolute positioning
                    I suggest you check that you have the correct M558 and G31 commands in config.g, and test the Z probe as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
                    • sleepless
                      M550 PRobo3d_R1+ ; Set machine name
                      M551 Psafety13 ; Set password
                      M552 S1 ; Enable network
                      M587 S"elvis" P"honeynut" ; Configure access point. You can delete this line once connected
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
                      M350 E16 I1 ; Configure microstepping with interpolation
                      M92 X160 Y160 Z1600 E816.32 ; Set steps per mm
                      M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
                      M201 X1000 Y1000 Z250 E250 ; Set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X15 Y15 Z0 S1 ; Set axis minima
                      M208 X230 Y254 Z200 S0 ; Set axis maxima
                      M574 Z1 S0 ; Set active low endstops
                      M574 X2 Y2 S1 ; Set active high endstops
                      M574 Z1 S2 ;
                      M558 P4 I1 H5 F150 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                      M557 X15:215 Y15:230 S50 ; Define mesh grid
                      M307 H0 A134.3 C404.8 D0.4 B0
                      M143 H0 S110 ; Set temperature limit for heater 0 to 110C
                      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                      M501 ;
                      M107 P0 S0.6 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M563 P0 D0 H1 ; Define tool 0
                      • sleepless
                        z endstop triggers when homing however fails to run bed probe sequence
                        • sleepless
                          when i try g30 it says not enough axes homes
                            dc42 administrators @sleepless last edited by
                            @sleepless said in Robo3d AUTOLEVEL Not Working:
                            In order to execute G30, the X and Y axes need to be flagged as having been homed. So either you hadn't homed X and Y between turning on the printer and sending G30, or you did something else (e.g. turned the motors off using M18 or M84) that caused them to be flagged as not homed.
                            • sleepless
                              ok i had to change g30 z0 to z-2now its doing autohoming, guess its time to calibrate the z height
                              • sleepless
                                as you can see the auto level doesn't seem to be working very well, Do you think i need to run a mesh grid calibration?
                                  Phaedrux Moderator @sleepless last edited by Phaedrux
                                  It's a good way to see your bed topography even if you don't use the compensation feature.
                                  Did you end up getting a probe?
                                  • sleepless
                                    no i did not get the probe yet. mainly because i havent seen a design for the robo x carriage that houses the bltouch and i dont have time to design it at the moment
                                      Does your print bed have levelling screws? If so then I suggest you do true bed levelling adjustment before you run mesh probing. See https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant.
                                      • sleepless
                                        Not sure what I did but its working again : ) and dialed in
                                        • sleepless
                                          ![alt text](0_1548801743166_Screenshot (32).png image url)
                                          • sleepless
                                            Hi can you point me to some literature about clearing the compensation and running the calibration sequence in as many points as possible?
                                              @sleepless Here's the relevant docs on mesh bed compensation
                                              https://duet3d.dozuki.com/Wiki/GCode#Section_G29_Detailed_Z_Probe
                                              https://duet3d.dozuki.com/Wiki/GCode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                                              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                                              The way to maximize the grid area is to take the size of your bed, and subtract the G31 X and Y offsets to get the area of the bed reachable by the probe. Then you can enter a M557 command into the gcode console with a really small grid spacing. The system will determine that it's too small, and suggest a new grid spacing that should maximise your probe points.
                                              • sleepless
                                                sleepless @Phaedrux last edited by
                                                @phaedrux thanks ill try this out
                                                • sleepless
                                                  ok so it turns out it was a mechanical issue. One of the endstops was a little loose so it would move when triggered. I tightened eveything up and now its looking much better
