Robo3d AUTOLEVEL Not Working
@sleepless Here's the relevant docs on mesh bed compensation
https://duet3d.dozuki.com/Wiki/GCode#Section_G29_Detailed_Z_Probe
https://duet3d.dozuki.com/Wiki/GCode#Section_M557_Set_Z_probe_point_or_define_probing_grid
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensationThe way to maximize the grid area is to take the size of your bed, and subtract the G31 X and Y offsets to get the area of the bed reachable by the probe. Then you can enter a M557 command into the gcode console with a really small grid spacing. The system will determine that it's too small, and suggest a new grid spacing that should maximise your probe points.
@phaedrux thanks ill try this out
ok so it turns out it was a mechanical issue. One of the endstops was a little loose so it would move when triggered. I tightened eveything up and now its looking much better
