    problem when going to test heaters in duet wifi 1.21
    • kostasbmw
      kostasbmw last edited by
      just finished with the kinematics in my corexy printer and tried to test the heaters
      heaters active pressed test heaters and i ger this message
      Extruder Control
      Feed amount in mm:
      Feedrate in mm/sec:
      User-Defined Macros
      Connect to your Duet to display Macro files
      Miscellaneous
      35 %
      × JavaScript Error
      A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
      Version: 1.21.2-dc42
      Message: Uncaught TypeError: Cannot read property 'drives' of undefined
      URL: http://192.168.0.118/js/dwc.js
      Line: 9102:35
      Error object: {}
      any ideas what to do???
        Please upgrade to main firmware 2.01 and Duet Web Control 1.22.5.
        kostasbmw 1 Reply Last reply Reply Quote 0
        • kostasbmw
          kostasbmw @dc42 last edited by
          thanks
