    'buzzing' belts
    crosshatching artifacts
    • shadowphile
      shadowphile last edited by shadowphile
      I'm in middle of fine tuning my extrusions.
      I noticed during all of this that my large vertical surfaces have a fine regular cross-hatching that in my mind is definitely an artifact of moving and extruding steps. I'm printing with esun pla+ through a Zesty Nimble on a large delta with a duet ethernet.
      There are discussions similar to this observation on that forum but this is more regular than those issues.
      While printing a 25mm cubic shell at about 20 mmps I grabbed a belt and clearly felt a high-pitched buzz. Should that be normal?
        Phaedrux Moderator @shadowphile last edited by
        @shadowphile Can you post a photo?
        • shadowphile
          well I was asking about the buzz 🙂
          But I will post a pic when I get home tonight.
          thanks.
            Well it's a vibration. If it's making noise something must be vibrating. So try tightening the belts if possible, or see if there is a part of the frame that is loose. You may be hitting a resonant speed as well, does it still happen if you go a bit slower or faster?
