    after new print z height get's a +2.0
    470
    • janko
      janko last edited by
      So I have this really weird issue which i just can't get figured out.
      The problem: when I start a print, all goes well. The printer starts with fixing the tilt on one plane, does a small ABL, primes and prints along, so far so good. However: after this print has finished and I want to start a second print, this print starts with a z height of +2 (eg: in stead of 0.2, because the first layer is 0.2mm, the printer starts on 2.2, which results in some nice airprinting no need saying 😛 ).
      The samen happens when i cancel a print and start a new one. Restarting the duet completely solves it for the next print.
      I have digged through the configfiles but can't figure out where that +2 comes from.
      Configfiles for my Duet Wifi:
      [0_1544888213532_download.zip](Uploading 0%)
      My startup g-code is:
      ; Startup Gcode
      M83
      M140 S[first_layer_bed_temperature] ; set bed temperature
      M190 S[first_layer_bed_temperature] ; wait for temperature
      M104 S[first_layer_temperature]
      M561 ; Clear any bed transform
      G32 ; Do a single probe
      G29 ; Load heightmap (you can use G29 S1 instead)
      G1 Z20.0 F100 ; Move Z to 20
      G1 X10 Y10 F900 ; Move Head to front left
      M109 S[first_layer_temperature]
      G0 X5 Y10 F9000 ; Go to front
      G0 Z0.2 ; Drop to bed
      G92 E0 ; zero the extruded length
      G1 X40 E25 F100 ; Extrude 25mm of filament in a 4cm line
      G1 E-1 F500 ; Retract a little
      G1 X80 F4000 ; Quickly wipe away from the filament line
      My End-gcode is:
      G10 P0 R-273.15 S-273.15 ; Turn off Tool0
      M140 S0 ; Turn off Bed
      M109 S0
      M106 S0 ; Object fan off
      G1 X0 Y0 ; Move Z to Z210
      G92 E0 ; Zero Extruder
      G1 E-2 F300 ; Retract 2mm
      M84 ; All motors Off
      • janko
        and the fileupload is refusing a bit:
        wetransferlink for the configfiles
          Which firmware version are you using? Prior to firmware 2.01, homing Z while bed compensation was active sometimes caused a Z offset.
          • janko
            Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
            WiFi Server Version: 1.21RC4(08b3)
            Web Interface Version: 1.22.3
              I don't recall an issue of that nature in 2.02RC2, but that's an old RC, so i suggest you upgrade to 2.02RC6. Also you should upgrade DuetWiFiServer to 1.21.
              janko 2 Replies Last reply Reply Quote 0
              • janko
                janko @dc42 last edited by
                @dc42 as soon as the current print is finished, i'll give that a spin and keep you posted here about the results
                • janko
                  @dc42 i think i finally found it 😄 When the ABL finishes, it puts the Z on +10 and starts moving to x20y20, when it reaches that point, the bed moves to z 0.2, but, the acceleration/speed of the Z-axis seemed to be too high, which made the motors skip steps. For the normal z-hop the acceleration is however no problem.
                  Seems adjusting the accelerationsettings solves it.
                    Thanks for the update!
