    Messed up duet wifi installation !
    Firmware installation
    • carlitototoundefined
      carlitototo
      So, I kinda broke the SD card that was sent with the Duet Wifi ( I know, terrible :') ) And I'm now trying to figure out a way to " re-do" everything, but can't do it...
      Following the installation guide, and, my computer ( running windows 10 ) still doesn't recognize the duet after installing the driver ( unknown USB device, in Device Manager ) , tested a few USB cable just to be shure of the issue, loaded the latest firmware on different SD cards ( 16Go, working well, in FAT 32 )... But still can't seem to be recognize, I'm kinda stuck on this one, any idea 🙂 ?
      Thanks !
      Carlito
        carlitototo
        Forgot to say !
        seems similaire to this topic : https://forum.duet3d.com/topic/2422/complete-download-needed-for-new-installation-confused
        But not the same at the same time... So strange !
          Have you seen the Troubleshooting section of the wiki, in particular https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond ?
            carlitototo
            Thanks for quick reply !
            The wiki is so big, missed that one !
            Infortunatly, nothing will do ! still no ports recognize, after trying tothe erase procedure multiple times... Sad to say, but I think (3D :P) that my duet is dead 😢 snif
            On a more serious note, going to try again tomorow just to be shure, and if no result, it's going to be a return:/
            Thank you so much for helping !
              carlitototo
              After many hours of trying ( ok, maybe not that many, like 3 h ) No results, I guess I'm turning to custumer service... So sad 😢 Hope they can tell me what happened !
              Thank you so much !
                dc42 administrators @carlitototo
                @carlitototo said in Messed up duet wifi installation !:
                Infortunatly, nothing will do ! still no ports recognize, after trying tothe erase procedure multiple times... Sad to say, but I think (3D :P) that my duet is dead snif
                Try a different USB port on your PC if you haven't already, also try rebooting the PC - especially if it is running Windows. If you've already done that, then go ahead and contact your supplier.
