    SOLVED duplicate files in macro and setting
    Firmware installation
    • antoine.voiry
      antoine.voiry last edited by antoine.voiry
      All,
      I upgraded my DUET WIFI to latest firmware (DUET WIFI BATCH 3).
      I now face 4 issues
      1. the version is still showing as 1.21 (see below)
      2. the files in MACRO, SETTING, and PLA are duplicated like if I was now able to call all the history
      3. the web browser complains of a 404 error
        dwc.js:2 GET http://p3steel.local/rr_download?name=0:/sys/oem.json 404 (file not found)
      4. diagnostic message requires to disconnect and reconnect to appear
      See diagnostic below
      Used output buffers: 4 of 32 (14 max)
      RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01
      Board ID: 08DAM-999TL-MQ4S4-6J1DG-3S46N-TPHRY
      Static ram used: 16152
      Dynamic ram used: 100440
      Recycled dynamic ram: 2192
      Stack ram used: 1224 current, 4448 maximum
      Never used ram: 7840
      Last reset 00:01:04 ago, cause: software
      Last software reset at 2018-12-16 22:53, reason: User, spinning module GCodes, available RAM 7888 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 28.9, current 29.7, max 29.9
      Supply voltage: min 13.0, current 13.1, max 13.3, under voltage events: 0, over voltage events: 0
      Date/time: 2018-12-16 23:10:36
      Slowest main loop (seconds): 0.013969; fastest: 0.000046
      MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 60:01:94:09:bc:4e
        WiFi Vcc 3.44, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15216
        WiFi IP address 10.0.0.18
        WiFi signal strength -58dBm, reconnections 0, sleep mode modem
        Socket states: 0 2 0 0 0 0 0 0
        === Expansion ===
        Used output buffers: 13 of 32 (24 max)
        Last reset 00:01:27 ago, cause: software
        Error status: 0
        MCU temperature: min 29.2, current 29.5, max 29.7
        Supply voltage: min 13.1, current 13.1, max 13.2, under voltage events: 0, over voltage events: 0
        Date/time: 2018-12-16 23:10:59
        Slowest main loop (seconds): 0.180053; fastest: 0.000112
        Segments left: 0
        === Network ===
      • WiFi -
        WiFi flash size 4194304, free heap 16680
        WiFi signal strength -57dBm, reconnections 0, sleep mode modem
        Socket states: 4 2 0 0 0 0 0 0
        === Expansion ===
        1. Upload the latest version of iap4e.bin through the Settings/General page of DWC, then try updating the firmware again.
        2. Do you mean that DWC is displaying every file twice, or something else?
        3. That 404 error is normal. You should only see the error message if you have the browser debugging console open. That file is used by some of our OEMs to customise DWC.
        4. That might be explained by the failure to upgrade the main firmware, if you also upgraded to the latest DWC.
        • antoine.voiry
          @dc42 said in duplicate files in macro and setting:
          iap4e
          1. This solves the issue, I now have
          Firmware Electronics: Duet WiFi 1.0 or 1.01
          Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
          WiFi Server Version: 1.21
          Web Interface Version: 1.22.5
          1. This is solved
          2. Ok, so that's not an issue
          3. This is solved
          Thanks!!
          Antoine
