    Solved Last issue (hopefully)
    • TOFUATSU
      TOFUATSU last edited by
      CoreXY, duet WiFi, 24v, titan extruder, E3D v6, dc42 ir sensor, 110vac heater bed and the rest from china.
      After I press the homeall command everything goes fantastic (thank you DC!!). Including the bed homing.
      Now when I start a print the extruder moves to position and the bed rises past the Endstop.
      I don’t even know where to begin?! (Artist)
      Here is my config file.
      ; generated by RepRapFirmware Configuration Tool on Sun Dec 16 2018 22:01:10 GMT-0500 (Eastern Standard Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M667 S1 ; Select CoreXY mode
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80 Y80 Z1600 E418.599 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X265 Y250 Z380 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      M558 P1 H0 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:190 Y15:190 S20 ; Define mesh grid
      M305 P1 T100000 B4724 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first tool
        Please post your homez.g and homeall.g files.
        TOFUATSU 1 Reply Last reply Reply Quote 0
        • TOFUATSU
          TOFUATSU @dc42 last edited by
          I figured it out...
          my leadscrew was off by a factor of 4x!!!
          • TOFUATSU
            TOFUATSU @TOFUATSU last edited by
            @tofuatsu
            So after heating up it would rise the bed 2.5mm x4
              I'm glad you solved it!
