    Piezo Z probe problems/ Seeking alternatives !!!
    4.0k
      I hear your frustrations.
      See this note about switches. https://reprap.org/wiki/Z_probe#Microswitch
      The mode you choose will depend on how the switch is wired. See the different modes in this link https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
      If it's already triggered that means it may need to be inverted by adding i1 to M558.
      You'll also need an X Y offset now in g31.
      • CozyPundefined
        CozyP
        Followed the instructions exactly as they dictated.
        Input the microswitch to E0 instead of Zendstop.
        Selected P4 on M558 command.
        It works. By hand. I hit the endstop and the machine moves to the various points. If I click the endstop, it moves to the next one.
        Will try the piezo probe on E0 and update you.
        Thank you very much for your time.
        • CozyPundefined
          CozyP
          AND IT WORKS. WITH THE PIEZO SENSOR.
          Is it possible to add this feature on Z leveling for future recommendation??? I believe many users will find this usefull, as setting BLtouch and IR probes is a nightmare. Sometimes, simplicity offers the best results.
          • CozyPundefined
            CozyP
            I can write the post myself for the Z leveling with microswitches or a simple piezo with pictures as examples too. let me know
              Have at it. Glad you got it working. Interested to see what you ended up with.
              • CozyPundefined
                CozyP
                Will do. just popped a new topic on a new problem that did arise. This topic problem is solved. Will start making a tutorial for microswitch or piezo leveling
