    Error while compile RADDS
    Firmware developers
    730
    • ffnull
      ffnull last edited by
      Helo. Im try to build RADDS to make my own firmware with moded shield. Im use build instruction and some useful info on forum. But right now im stuck on this errors.
      Building target: RepRapFirmware-RADDS.elf
      Invoking: Cross G++ Linker
      arm-none-eabi-gcc -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m3 -T"C:\Eclipse\Firmware\CoreNG\variants\RADDS\linker_scripts\gcc\flash.ld" -Wl,-Map,"C:\Eclipse\Firmware\RepRapFirmware\RADDS_RTOS/RepRapFirmware-RADDS.map" -o "RepRapFirmware-RADDS.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Eclipse\Firmware\CoreNG\SAM3X8E\cores\arduino\syscalls.o" ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/RADDS/Network.o ./src/ObjectModel/ObjectModel.o ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXYUVKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/StepTimer.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/HeaterProtection.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/RestorePoint.o ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o ./src/Fans/DotStarLed.o ./src/Fans/Fan.o ./src/Fans/Tacho.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageBuffer.o ./src/CAN/CanSender.o ./src/DmacManager.o ./src/IoPorts.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/Spindle.o ./src/Tasks.o ./src/ZProbe.o ./src/ZProbeProgrammer.o -lCoreNG -lFreeRTOS -lRRFLibraries -Wl,--end-group -lm
      c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lCoreNG
      c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lFreeRTOS
      c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lRRFLibraries
      collect2.exe: error: ld returned 1 exit status
      makefile:61: recipe for target 'RepRapFirmware-RADDS.elf' failed
      make: *** [RepRapFirmware-RADDS.elf] Error 1
        Looks like you didn't build the libraries first, or you built the wrong configuration of the libraries. See the BuildInstructions.md file
        • ffnull
          Im do by buildinstructions. Im use RepRapFirmware-2-dev FreeRTOS-master FreeRTOS-master RRFLibraries-master. Compile first Core FreeRtos RRF. Then clean RepRap. Select RADDS-FreeRTOS and got errors
            You probably didn't set the correct build configuration of the libraries. You need to build the RADDS_RTOS configuration of CoreNG, the SAM3X_RTOS configuration of RRFLibraries, and the SAM3X configuration of FreeRTOS.
              I just spotted an error in the linker command line that you posted, that meant you would also need to have build the RADDS (non-RTOS) configuration of CoreNG. I've just committed a fix to the .cproject file of the RepRapFirmware project.
              • ffnull
                Ok. Redownload brunch. Set correct build configurations on all libraris and recompile all. Builds without error. But at the end Eclipse show error on splash screen:
                Errors occurred during the build.
                Errors running builder 'CDT Builder' on project 'RepRapFirmware'.
                Resource '/RepRapFirmware/RADDS_RTOS/sources.mk' does not exist.
                • ffnull
                  FIXED! Cleanup all again. And compiles without issues. Thank You!
                  • ffnull
                    Last question. Im do remap pinouts of RADDS. Im try to adopt another shield. On my board STEP pins is Analog Pins on DUE. Im try to write A11,A12... But its not correct. How to correct?
                      If you change the step pins, you also need to change the 3 functions at the end of the Platform.h file. For best performance, assign all of the step pins to the same PIO port.
                      • ffnull
                        Thanks. But how to use analog pins? Im try A10, A11 ... but its not correct. How?
                          dc42 administrators @ffnull last edited by
                          @ffnull said in Error while compile RADDS:
                          Those pins have equivalent digital pin numbers. Read the Arduino Due documentation to find what the mapping is.
                          • ffnull
                            Huh. Im idiot. Im forgot about it. Thnx
