    Z probe
    • ronnien59
      ronnien59 last edited by
      I have a question. First all I have a 12 VDC power supply on my duet wifi. I would like to know if I can also add a 24 VDC power supply to run my Z probe. I am using a voltage divider 15K and 2.2K resistors that reduce output voltage to approximately 3.16 VDC. Is it possible to then use this voltage to trigger my z probe on the board connected to the ground and in pins on the probe pins? Or would it be better to run a relay and connect the 3.3 VDC pin to the in pin?
        This is covered at https://duet3d.com/wiki/Connecting_a_Z_probe#PNP_output_normally-open_inductive_or_capacitive_sensor.
        • ronnien59
          @dc42:
          Thanks, I will break out the my bread board and test for the correct resistors
          • ronnien59
            Well now have my probe running off of 24VDC. R1 15K and R2 2.2K 3VDC out put.
