    Duet Web Control 2.0.0-RC3 is ready
    Duet Web Control
    50
    147
    27.4k
    • wilrikerundefined
      wilriker @kraegar
      @kraegar said in Duet Web Control 2.0.0-RC2 is ready:
      Not exactly related to the new version, but I'd love to see the ability to move gcode files into sub directories from within the GUI.
      That was possible in DWC1 already. I have not yet tried in DWC2, though.
      Manuel
      My Tool Collection
      kraegarundefined 1 Reply Last reply Reply Quote 0
      • kraegarundefined
        kraegar @wilriker
        @wilriker How? I can make a folder, but can't figure a way to move a gcode file between folders. Unless I just upload a new copy of them.
        Co-Creator of the RailcoreII CoreXY printer
        https://www.thingiverse.com/thing:2407174
        • wilrikerundefined
          wilriker @kraegar
          @kraegar Select them via the checkbox and then drag-n-drop. To get them a folder up use the bread-crumbs above the file list.
          P.S.: Just tested: you don't even have to select them via the checkboxes. Single files can just be drag-n-dropped directly. Use the "link" (that usually opens the wanna-print-this-dialog) as a click-location.
          Manuel
          My Tool Collection
          • kraegarundefined
            kraegar @wilriker
            @wilriker Hmm. What browser? Isn't working for me in either. I'm on chrome. Could be user error I guess
            • wilrikerundefined
              wilriker @kraegar
              @kraegar I use Vivaldi but that is basically a Chrome with a modified UI.
              Are we both talking about DWC1? Because that's where it works. I just tried and it seems to not be implemented in DWC2 so far.
              Manuel
              My Tool Collection
              • kraegarundefined
                kraegar
                Yep. Maybe it's being interefered with by a plugin or something on my side. Going to stop spamming this thread with it.
                • kraegarundefined
                  kraegar
                  Ok, yep, it works in DWC1, not 2
                    dc42 administrators @sigxcpu
                    @sigxcpu said in Duet Web Control 2.0.0-RC2 is ready:
                    Then something is broken in backlog implementation because the Nth+1 connection gets TCP RST instead of waiting. Here is how to find out N:
                    I've found a couple of reasons for these issues:
                    1. DuetWiFiServer is coded to reject TCP connections if there are no listeners available for them. There are 4 HTTP responders, so an attempt to open a 5th concurrent HTTP connection is refused. I think this is the right thing to do. With luck, the browser will respect it.
                    2. The main problem I have identified is that DuetWiFiServer is running out of buffer space when returning multiple files concurrently. This results in the connection being aborted. I plan to change the code to buffer outgoing messages in our own code instead of in lwip, so that I can be sure that sufficient memory is available before accepting a message from the Duet.
                    sigxcpuundefined 1 Reply Last reply Reply Quote 0
                    • sigxcpuundefined
                      sigxcpu @dc42
                      @dc42 said in Duet Web Control 2.0.0-RC2 is ready:
                      Maybe I don't get this right, but 4 HTTP responders and backlog = 8 means that we can have up to 12 simultaneous connections, 4 accepted, 8 pending. The reset/connection refused should happen on the 13th concurrent attempt.
                      Based on your description (thanks, btw) and my network knowledge, I am pretty sure that the actual backlog is 0 if the 5th connection is refused.
                      • percarundefined
                        percar
                        I have now been using the DWC 2.0.0 R2 for a few days now. I love the format. I also understand that this is a new undertaking and bugs are expected. Please continue in this direction because I feel that the new DWC format will be awesome once the bugs are gone. I ran into very few issues with one being the download time for the Gcodes to be printed. Also there have been a few disconnects which I have not really investigated the reason behind the disconnects. I am sure as time progresses this will all be sorted out. Again Thanks
                        • gtj0undefined
                          gtj0
                          I have to say... I'm not a fan. Sorry.
                          Non sales/marketing users interfaces need to be designed for people who are going to be sitting in front of it and using it for 8 hours a day. Here are some things I'd like to see...
                          Get rid of the spacing in the left menu, then you don't need the major items to collapse. Keep it compact so everything you need is in the smallest space that's still usable.
                          The temperature plots are nice but I'd rather see a grid of my macros in that spot. Maybe you could keep the plots if the spacing in the other widgets were reduced.
                          When you scroll, the menu and top widgets should be pinned. For instance, when you're looking at the macros or system files, the only thing that should scroll is the list of files themselves. Even the list column headers and upload buttons should be fixed.
                          For devices with 3 movement axes and 1 or more extruders, the movement buttons should be laid out in a cross pattern. Vertical row for Y, horizontal row for X, then to the side, a vertical row for Z and each extruder.
                          These may be in the works but...
                          The height map display doesn't show the statistical analysis so if you look at it later you don't know the magnitude of the colors.
                          There's no display of system information.
                          • 3dmntbighkerundefined
                            3dmntbighker
                            How do I change the default fan from "Tool Fan" to "Fan 0"? I can't even hide Tool Fan, but I have to keep manually showing Fan 0, which is the tool fan.
                            Scratch built CoreXY with Maestro
                            Heavily modified Ender 3 with Maestro
                            MPCNC work in progress with Duet WiFi
                            • kazolarundefined
                              kazolar
                              Maybe this was answered, but where is the diagnostics page in the new UI. I can't find drives/current/end stop status screen.
                              • wilrikerundefined
                                wilriker @kazolar
                                @kazolar I don't think this is there, yet.
                                Manuel
                                My Tool Collection
                                kazolarundefined 1 Reply Last reply Reply Quote 0
                                • r123undefined
                                  r123
                                  Have not yet installed this. But would love to see a screenshot from someone who has so as to understand better what everyone's talking about! 😉
                                  • kazolarundefined
                                    kazolar @wilriker
                                    @wilriker ended up reverting the firmware to the previous RC build -- which removed the DWC upgrade, oh well...seems a bit raw as of now.
                                    • patakopecekundefined
                                      patakopecek
                                      idk why but when I try to load code files my browser hangs, it just freezes
                                        patakopecek
                                        And I am unable to upload .bin files, which are essential for fw updating, until @dc42 starts packing his .zip with DWC2, and for some reason when I just removed the dwc1 files from the zip it would not let me update, it said that this package is not compatible with my electronics, I know it is because when I moved it to the sd card manually it worked like a charm
                                          patakopecek
                                          And I really miss a general purpose upload button for FW, DWC, Gcode etc.
                                          • Jacotheronundefined
                                            Jacotheron
                                            I have uploaded a few screenshots to my DropBox at https://www.dropbox.com/sh/s9jyzl8a9nmqbow/AAB5x4WU3fbKofEBBhQ3tatNa?dl=0
                                            The naming is simple: if it starts with a 0, it is the light theme, and those that start with the 1 is the dark theme. I did not screenshot everything, it is easy enough to work from the light to imagine what the dark looks like.
                                            Screenshots were taken in Firefox, on a full HD display.
                                            Notes: 1) While I don't have the height map, enabled, I did screenshot it to show what details it can show. 2) "WanhaoD5S" is the name I gave the printer. 3) My printer is Cartesian, with a single extruder and heatbed. 4) While I have a webcam on it, I did not screenshot it, as it provides no real added value (it simply displays the images, or iframe in a big block). 5) I did not screenshot my config file in the file editor, since it may contain passwords and other info I would rather not have visible on the Internet. 6) Yes, I have a bunch of Macros. 7) MCU temperature, I like to be able to see it in the graph [during our recent heatwave it hovered around 50C].
                                            For me this DWC simply works - there is small issues I found (mentioned above), but none that are a reason to revert to the previous version (at this time).
                                            While I am here, I want to add a few things to the issues I have found:
                                            • Colors used in the Dark theme, quite a lot of the colors melts into the background. It seems that the Blue used is the same as in the light theme, maybe change it slightly.
                                            • The Extrusion Control in the Dashboard, those buttons (specifically the Feed Amount and Feedrate) looks "disabled" even though they are active and working
                                            As to my opinion on the direction DWC is headed:
                                            • Change is needed from the version 1, using more modern and newer technologies. On this DWC2 is making good progress, but other sections needs to also be updated to prevent issues that many here have posted (not being able to connect, blank screens etc).
                                            • The Interface needs a big overhaul from version 1. While these visual changes are quite a lot, I think it may be too far from what we had for a single step. The animations should be a lot quicker, Yesterday when I did my M600 tests, the buttons in the Retract/Extrude section took too long before becoming "available" to click between clicks (I had 1m of bowden tube to retract/extrude) that I simply went to the PanelDue instead. The new interface works well on big screens with the current padding/white space used, but on smaller screens I keep scrolling to find the things I need (perhaps look at more Media Queries).
                                            • Browser caching needs to be used and optimized to use even less resources on the Duet.
                                            Ultimately I think this is rather a Beta version, due to the amount of work still required.
                                            That said, thank you for sharing it, it helps to gauge the community to help steer the development in the right direction.
                                            Alas, it seems that my phone also had trouble connecting now - getting the white screen. Though a printer restart and it connects again (not always practical).
