    Duet Web Control 2.0.0-RC3 is ready
    Duet Web Control
    50
    147
    27.4k
    • Edgars Batnaundefined
      Edgars Batna
      @chrishamm
      1. If I go to G-Code Console, select a whole line by first clicking right of it and dragging all the way left and some more, then hit CTRL+C, then select the input box and hit CTRL+V, there's an extra TAB character in the copied text.
      2. The mesh grid calibration results are no longer displayed after running it. I need to hit F5 so that it gets the latest data and then manually go to the Height Map.
      3. I can't find a Diagnostics button anywhere.
      4. Extrude and retract buttons are unusable. config: 0_1547976629806_config_edit.g
      • DocTruckerundefined
        DocTrucker
        The g-code console no longer logs a message at start of build. I found that behaviour useful.
        Edit: Saves going through:
        (current time) - (elapsed time) + (simulated time) = (accurate finish time)
        • nhofundefined
          nhof
          One minor headache I have with RC3 is that I can no longer enter tab characters using the config text editor.
          • SupraGuyundefined
            SupraGuy
            I'm having an odd issue.
            Duet Wifi 1.04
            Firmware 2.02
            Wifi server 1.22
            DWC 2.0.0RC3
            Sometimes I want to adjust the home position for the Z axis manually, instead of letting the Z probe do it. (I know, I shouldn't need to, and I should just change the Z offset, but I get different results at different temperatures, so...)
            Anyway, entering into the G code console:
            M558 P0
            Then using the "home Z" button or the "home all" button.
            It mostly works as expected, but for whatever reason, on the dialog box to jog the Z axis, I can only press each button once. After that there is a spinning circle in place of the adjust amount, and it will not respond to another click.
            It does work when running a G29 mesh level, and I can press the same button repeatedly with the probe set to 0/manual, but it does not work with homing the Z axis.
            I didn't end up trying alternate browsers, I only used Chrome, but I did use the Chrome on my PC, and I also tried my phone.
            Lead screw driven printer, powered by Duet 2 Wifi
            MPCNC powered by Duet 2 Wifi
            CoreXY printer driven by Duet 3 6HC
            LowRider CNC powered by Duet 2 Wifi
            wilrikerundefined calvincdundefined themelleundefined 3 Replies Last reply Reply Quote 0
            • wilrikerundefined
              wilriker @SupraGuy
              @supraguy You share this issue with me and at least one other user. 😉
              Manuel
              My Tool Collection
              • calvincdundefined
                calvincd @SupraGuy
                @supraguy
                I am also having a problem with the height adjustment buttons. If I try to run auto calibration and check height manually, my height adjustment buttons will not refresh. If I run the calibration and exit and then use the homeall or home X Y or Z axis the button will not refresh.
                • themelleundefined
                  themelle @SupraGuy
                  @supraguy said in Duet Web Control 2.0.0-RC3 is ready:
                  Same here when trying to run manual Delta calibration using G32.
                  config.g contains
                  M558 P0
                  G31 X0 Y0
                  Using the old DWC (/reprap.htm) the process does work, though.
