    Cannot jog nozzle to bed when setting Z offset.
    • Steve Lynch
      Steve Lynch last edited by
      I just installed a new hotend / extruder, and when I try to jog to the bed to set z0, it will not let me go that far.. I've homed, I've tried every setting I can find, but cannot go past the soft end stop.. in marlin I can M211 s0, but duet does not like that gcode.. Thoughts?
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
        If you can't get the nozzle to go low enough, you can tell the firmware that you're z height is higher than it actually is with G92 Z10 (which would make the firmware think the nozzle is 10mm above the bed.) That should let you get it to touch the bed, then you can send G92 Z0 to tell it that it's actually touching the bed.
          dc42 administrators @Steve Lynch last edited by
          @steve-lynch said in Cannot jog nozzle to bed when setting Z offset.:
          You can send M564 S0 to turn off axis limit checking.
          • Steve Lynch
            Thanks guys! That worked! 🙂
