    Testing Duex5... cant get fans to work
    • nikker
      nikker last edited by
      I have a new Duet ethernet and Duex 5 I am setting up. I have power (24.15 volts) going to the Duet and Duex5 and checked both with a multi-meter. Using M115 is get "FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2018-12-24b1" so it should be connected correctly. I am trying to test a 12 volt fan so on the Duex5 I have the V_FAN_JUMPER in the middle for 12 volts. I have in my config.g for fans the following:
      M106 P0 S1 I0 F500 H-1 ;C"Tool1" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1 C"Tool2" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 C"Tool3" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P3 S1 I0 F500 H-1 C"Tool4" ; Set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P4 S1 I0 F500 H-1 C"Tool5" ; Set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P5 S1 I0 F500 H-1 C"Tool6" ; Set fan 5 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P6 S1 I0 F500 H-1 C"Tool7" ; Set fan 6 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P7 S1 I0 F500 H-1 C"Tool8" ; Set fan 7 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P8 S1 I0 F500 H-1 C"Tool9" ; Set fan 8 value, PWM signal inversion and frequency. Thermostatic control is turned off
      When I connect a 12 volt fan to the Duex5 fan 3 and adjust it in DWC i get no movement. I also checked with a volt meter and see no voltage. Any tips??
      • nikker
        Think I have i may have it figured out but cant test it as I dont have a jumper... but it looks like I have to set the fan voltage jumper to 12 volts as well as the 12v EN jumper. Can anyone confirm this? Thanks.
          dc42 administrators @nikker last edited by
          @nikker said in Testing Duex5... cant get fans to work:
          If your VIN is 24V, that is correct. If VIN is 12V, set the fan voltage selector jumper to VIN instead of to 12V.
