    M558 P1 selects Z probe type 1 = Z probe Mode 1?
    • Axel-H
      Axel-H last edited by
      in https://duet3d.com/wiki/Connecting_a_Z_probe it is unspecified what the different types of z probe is and it is also compleatly unspecified how to set to the different z probe modes?
      My guess is that the types might refer to the different modes?
      If my understanding is correct then mode (type) 5 is for a regular makerbot type bord on the Z endstop connector and simular?
        I have amended the working of the text on that wiki page:
        To configure the firmware to recognise the output mode of the Z probe you are using and which pin it is connected to, use the P parameter of the the M558 command in config.g. For example, M558 P1 selects Z probe mode 1.
        Type 5 is suitable for any digital output Z probe that doesn't need or can't handle a strong pullup resistor.
        • Axel-H
          Thank you,
          pot?
          I have got it working if I connect the endstop card on E1 and use P4.
          If I understand the site correctly 1-3 and 5 refer to probes connected to the probe connectors and 4 for end stop on E0, and 6 for E1?
          Form what I can see it is not possible to use the Z end stop connector for probing?
          Given that I use a simple endstop card for probing right now but that I need keep the probe connector free for testing of more advanced probes in the future and that I am planing to use E0 and E1 for fillament monitoring I would prefer to use the Z endstop connector for simple probing if possible.
            I corrected the typo.
            Currently the Z endstop input can't be used for a Z probe. I'll add this to the firmware wish list.
            What type of Z probe do you have? You may be able to use the Z probe connector.
            • Axel-H
              Thanks 🙂
              At the moment I use a 1.2v makerbot type endstop that are default high and I needed to rewire it slightly to give 0 as default output instead of 1000.
              The last version of the firmware seem to change something so it sees default high end stops as always triggered and I was unable to set it to trigger when it changed from 1000 to 0
                In recent firmware versions you can use the I1 parameter on the M558 command to change the polarity to active low for all Z probe types. So no need to rewire your endstop.
                • Axel-H
                  aha, thank you. I didn't find that piece of information when I was looking, It works well now so I might not change it back right away.
