    Duet wifi and anycubic i3 mega
    • mtthws
      mtthws last edited by
      I am currently having lots of issues with my anycubic i3 mega trigorilla board. I am looking at replacing it with a duet wifi board. I am guessing I am going to have to mount the board out side the case rather than upside down in it with the power supply. I think I saw something saying either the motor or end stop connectors on the duet are nonstandard, so I may need to swap those out. Is there anything else I should be aware of?
      I am probably going to add a bltouch sensor at the same time, which seems like it should not be a big deal. Are there any other upgrades people recommend while I am at it?
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @mtthws last edited by
        @mtthws Endstops are different, the 3.3vdc is the center pin of the three. If that board is a RAMPS variant see: https://duet3d.dozuki.com/Wiki/Wiring_and_hardware_differences_from_RAMPS_etc
        mtthws 1 Reply Last reply Reply Quote 0
        • mtthws
          mtthws @Stephen6309 last edited by
          @stephen6309 thanks
            That's right, the major different is the pinout of the 3-pin endstop connectors. With RAMPS and most other boards, the most common type of endstop (a microswitch) uses the centre pin and one of the outside pins, which guarantees that many users plug the connector in the wrong way round and short out the 5V regulator. The designers of the original Duet changed the pinout so that reversing the connector does no harm.
            The motor connections are the same: one phase connected to the two pins at one end of the connector, and the other phase connected to the two pins at the other end.
            • mtthws
              mtthws @dc42 last edited by
              @dc42 sorry I missed your reply. Thanks.
              Out of curiosity could I just skip redoing the stop sensors and just do sensorless homing? Not sure if you need end stop sensors at all if you enable that, and I believe this board supports that.
                dc42 administrators @mtthws last edited by
                @mtthws said in Duet wifi and anycubic i3 mega:
                Yes you could do that, but you would need to spend time finding suitable motor current and stall sensitivity settings. See the wiki page on stall detection.
