    M574 am i allowed to change endstop type on the fly?
    714
    • gavatron3000
      gavatron3000 last edited by
      my b axis is configured to be a sensorless endstop for homing and this works well as it loads filament during a tool change, on unloading id like it to home in reverse to a physical switch by changing M574 from sensorless to using a switch, then revert back to sensorless for the rest of the tool change.
      is this allowed by the firmware?
      or am i able to configure sensorless for max endstop and switch for minimum?
      cheers
        You can configure the firmware in real time. So any gcode commands you issue will be in effect when you issue them and in the order you issue them. In other words, you can do pretty much anything you want in a macro.
        • gavatron3000
          ok cheers, thanks mate
          • gavatron3000
            hmmm, i dont think it sticks during macro, i cant get this to reliably change endstop config on the fly. does it only work within config.g?
            Phaedrux dc42 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @gavatron3000 last edited by
              Can you post your files?
                dc42 administrators @gavatron3000 last edited by dc42
                @gavatron3000 said in M574 am i allowed to change endstop type on the fly?:
                You can use M574 at any time. If you need it to be delayed until all previous moves have completed, you might need to use M400 before it. I'm out if the office so I can't easily check right now.
                • gavatron3000
                  Here's one of the macro's that I switch the endstops, I'll add M400 hopefully tomorrow when I get a chance and see if that improves things
                  M591 D0 P2 C3 S0 ; deactivate filament sensor
                  M574 B2 S0 ; set B axis max endstop to switched low
                  G91 ; relative moves
                  G1 B30 S1 F3000 ; feed filament to filament sensor
                  G92 B0 ; force B to 0mm
                  G1 B20 F3000 ; feed a bit more to reliably switch sensor and reach tube
                  M400 ; wait till moves finish
                  M574 B2 S3 ; set B axis max endstop to sensorless
                  M581 E0 S0 T2 C0 ; activate trigger 2 on falling edge
                  M582 T2 ; check filament sensor to confirm loading successful
                  G4 P4000 ; trial wait to signify it progress
                  M913 B50 ; reduce motor current to 50% to prevent grinding
                  M915 B S5 F0 ; set stall guard parameters
                  G1 S1 B550 F3600 ; fast feed filament into extruder
                  M591 D0 P2 C3 S1 ; activate filament sensor
                  G90 ; absolute moves
                    I've checked, and you do need to use M400 before M574 if you need to guarantee that any regular moves have completed before the M574 takes effect. But endstop configuration doesn't affect regulator moves, and any homing move causes a pipeline stall anyway. So at present I can't think of a case where the M400 would actually be essential.
                    • gavatron3000
                      Ok no worries. I assume as soon as the m574 is issued the effect is instant?
                        Yes.
                        • gavatron3000
                          thought id report back....
                          so i had my offending B-axis playing up as described by not conforming to the on the fly M574 commands. originally it was connected to the E2 driver on my duex2. i read on the wiki in regards to M591 not being able to be used on these pins so i thought id see if it affected the endstops too. so i changed A and B around so the B axis is now on the E1 driver on the duet main board and it works as intended!
