    M558 bug?
    • buzzby
      buzzby last edited by
      I have been playing around trying to get my system to do multiple probes of the bed and have added the A parameter to my M558 line.
      I have found that if A is set to a number higher than 31 it defaults to 0. Not sure if this is a bug in the code or just an error in the documentation as no limit is expressed.
      Just wanted to let people know.
        Thanks for reporting this, it's a bug. The limit should be 31, and if you specify a higher value in the A parameter then it should set it to 31. I'll fix it in the next release.
