    Solved Warranty replacement fried?
    Order discussion
    2017
    • siblues
      siblues last edited by
      I just tried configuring my warranty replacement and everything was working fine until I tried heating the bed and now the board will not turn on the led's will only turn on with the usb connection.I tested the power terminals for the main power and they are reading 1.9v instead of the 13.4v the psu is currently reading.I just replaced the heatbed and entire hotend and all the wiring for both.I don't know if you rememebre me but this just happened to me with my new board from Filastruder.
        dc42 administrators @siblues last edited by
        @siblues said in Warranty replacement fried?:
        Do you mean that you have 1.9V across the VIN terminals of the Duet, but 13.4V across the terminals of the PSU that is supplying is? If that's what you mean, it can only be the result of a problem in the cable between the two, or you haven't tightened the VIN terminal block screws.
        • siblues
          Yup that is what I am getting with no led's turning on whatsoever on the duet but they do turn on with the usb.I have removed the cables and tested the psu and it is at 13.4 and if I remove the cables from the duet they also show 13.4 but when they are installed into the terminals and checked with the psu on they show under 2v.
          • aidar
            aidar last edited by aidar
            Can you post pictures, where from exactly you measuring this voltage and how your wires are connected to Duet?
            • siblues
              siblues last edited by siblues
              I am checking voltage at the power in terminals in this picture.
              power wiring
              • aidar
                Looks to me that your + wire at power terminal is not fully inserted. Please recheck that wires are in good contact with terminal and properly tightened.
                Am i understand you right : with psu connected to duet and powered up you have less than 2 v on duet power terminal but over 13 v on psu terminal same time?
                • siblues
                  Yeah I saw that the reason it is installed like that is because the first few times they were pushed in as far as they could go and it still wasn't working so I made sure the plastic on the terminal was not interfering with the connection.I can try to reinstall them again but I have done it 4 or 5 times already with no luck.The board was working fine while I loaded my config and updated the firmware.I then tested the fans and configured them and everything was ok and when I tested the bed the board shut off and didn't turn back on.The bed reads .9ohms it is a bit low but I don't see that being the problem.This is how the leds are behaving when using the usb.
                  USB Led's
                    @siblues, after removing the lead, unscrew the terminal screw a lot before you push it in again. Sometimes the wire can get trapped underneath the rising clamp instead of above it.
                    • siblues
                      I just removed the cables and reinstalled them and still no luck here are two pics of the wires screwed into the blocks.Sorry about the poor quality of the pics.
                      1st power wire
                      2nd power wire
                      • siblues
                        Do you think there could be a problem with the actual terminal block?
                        PlasticMetal dc42 2 Replies Last reply Reply Quote 0
                        • crynool
                          crynool last edited by crynool
                          What is the resistance saying between the terminal the wire end attached to the power supply?
                          If there is a connection issue between the terminal and the cable this could give you a hint
                          • PlasticMetal
                            PlasticMetal @siblues last edited by
                            I have a few ideas, assuming the cable is properly inserted into the terminal and attached to the PSU. This is one - if possible, check the soldering on the underside of the board, and make sure it isn't cracked or lifted.
                            Another is a possible short. From what you've posted, I think you've measured the voltage at the PSU while it's connected to the board, and the board is powered up. However, if your 13.4V PSU measurement was taken while the board is off or disconnected, but the board shows 1.9V once it's powered on, recheck the PSU in that state. If it is now showing 1.9V, that implies a short on the board or in the cabling, and the PSU is dropping into a fault condition to protect itself. Cycling the AC power or disconnecting the load should reset it.
                            One more thought - is the power cable direct from the PSU to the Duet, or is there a switch between the two? (It may seem odd to switch the 12V, but there could be valid reasons.) If there's a switch, bypass it.
                            As @crynool suggested, check the resistance of the power cabling itself. It, or a crimped-on terminal/ferrule, may be damaged.
                              dc42 administrators @siblues last edited by dc42
                              Where are you measuring the VIN voltage on your Duet with the multimeter? I normally touch the multimeter probes on the tops of the screws in the terminal block. That way I know that I am measuring the voltage that is reaching the Duet terminal block.
                              • siblues
                                I am checking on the screws.i checked the PSU both connected and disconnected from the Duet and it reads 13.4 both ways.I don't have a switch between the Duet and PSU and the cables are a continuous piece of 10awg cable with the crimp connectors on both ends.I will check the resistance now and get back to you I will also check the solder joints on the terminal block.I don't think it is a wire issue because it was working fine and it wasn't moved at all and when the bed started to heat the Duet turned off and we have the current problem which kind of seems like a failure of some sort.
                                • siblues
                                  I totally removed the board and psu from the printer and used a new set of power wires and made sure they were installed into the block correctly and it still doesn't power on.I also checked the terminal block connections to the board and continuity from the screw to the soldered pins on the board are fine.I looked at the board and nothing that I can see shows any physical damage.I also checked the VSSA fuse and it is giving me a reading of .9-1.0 ohm.Anything else I can check?
                                  • crynool
                                    Start with removing all cables/wires, just let the ones connected which you need to control the Duet (if it is Wifi, even better) & power.
                                    Just to make sure no other wire is creating a short (which isn't enough to blow a fuse but to have the PSU running in some sort of failsafe).
                                    What is the Amperage on that line when the Voltage is dropping?
                                    • siblues
                                      That is what I just did the only wires connected to the Duet Wifi were vin and ground and it was reading less than 2v and the psu was supplying 13.4v.
                                      • crynool
                                        Tried swapping the PSU? Sounds odd ... but apart from the Duet, this is the only piece which you didn't replace yet?
                                        • siblues
                                          I ended up spending quite a bit more than I wanted to and a better PSU is on my list but I don't just want to throw money at the problem.i purchased the best when it came to the controller to try to avoid that in the first place.
                                          • crynool
                                            I mean, at least you can try ... sort of cheap ATX PSU just for troubleshooting.
                                            Shorten PS_ON & GND, have an old HD Power connector connecting to VIN
                                            • siblues
                                              I don't have one laying around but I can order a new Meanwell and try it .I am going to try the PSU I have on my Smoothieboard and if it works I highly doubt it's the PSU.
                                              • sigxcpu
                                                sigxcpu last edited by
                                                Set your multimeter to 10A scale and connect it in series with the Duet. If there is a short, it should jump (above 10A most likely). If the PSU is at fault you will see much less current than 10A.
                                                • siblues
                                                  Crynool to my disbelief it was the PSU.You my friend hit the nail on the head.I swapped out my psu for a friends and it is working just fine so I am going to order one today.Thanks for all the help
                                                  • crynool
                                                    Glad you sorted it out 😄
